A Simple Way to Purge..
M
member 5159
Guest
websnail said:
The Hat said:
I found hot glue works great but after a couple of uses the glue tends to let go altogether and then has to be reapplied,
thats why I only use Araldite adhesive now. (Much stronger bond)
I've actually had problems with epoxy resins relating to brittleness of the bond, etc... but the glue sticks I'm using are a serious recipe designed for this sort of thing rather than hobby glue sticks so that might explain why my results differ.
Could you advise Name of your Glue sticks. Like The Hat I have not found the typical hobby sticks to be very good, like him I use Araldite but only the 24 hour variety again with the 5 minute versions which never seem to feed out equal amounts of resin and hardener
