palombian
- Feb 4, 2014
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
My MX7600 printer has a long history of messing ink while purging.
It is a pigment printer but seems to share most of the hardware with dye ink All-in-ones of the same age.
I thought have solved it by guiding the purge tube to a potty, but the wipers stayed very dirty and there is ink splashed on the timing strip.
So I did my usual cleaning by dripping some "pharmacist solution" on the pads and let purge.
Sprayed some on the wipers also (without dipping it up, maybe a bad idea).
After some pages I got the 5C00 error.
Could the sensor be dirty and does someone know where it is located ?
Continued:
I removed the top of the printer and cleaned everything around the purge unit but no avail.
After 3 light bumps (no rattles) the printer stops with the error, before the carriage is moved to the right.
So I don't think it is the sensor itself but something that is blocked.
Continued:
