Anadrol
- Feb 17, 2014
- Canon Pixma Pro-1
Hi all,
As strange as it sounds, while I can calibrate easily dye based printers,
it's a total disaster with pigment based ones !
This happens with PLAIN PAPER, I don't have this issue on glossy paper.
And yes, I absolutely need to print on plain, I print on 100g plain paper.
I did contact Xrite but they aren't of any help !
I own:
Pixma PRO-1 with OEM inks.
Pixma PRO-10S with OEM inks.
Pixma PRO-100S with OEM inks.
Canon MG7150 with Chinese inks and a CISS.
I calibrate using Xrite i1Profiler with a i1 PRO 2 spectrophotometer.
I was very careful to disable color management when printing the test charts, with highest print quality.
I did select RGB when profiling, and made dual scans for each line, I did optimise for best quality.
I was careful to not have marks that occur when the paper becomes bumpy when wet,
and the print head scrapes the paper (you can see that on the green color of the PRO-10S result chart).
I did use 2033 patches because if I use 6000 patches, well i1Profiler crashes ! (does it happen to anyone else ?).
Of course, I did print the result charts with ICC profiles enabled.
By the way, please note that pigment inks make a much more evenly result on plain paper,
contrary to what I've read online, that you need dye inks for plain paper !
Here are the results:
Red is especially terrible on the PRO-10S, while it has a dedicated red ink cartridge !
Exactly the same happens with the PRO-1.
One can notice that Chinese inks have gorgeous colors on the MG7150, seem better for me than the PRO-100S with OEM inks !
I bought these inks for LESS THAN 5 USD PER LITER ! Yes per liter !
These guys deserve publicity http://www.aomya.com.cn/ perfect customer service from A to Z !
One very strange thing that I noticed, is that when I make the profile on glossy paper for the PRO-10S or the PRO-1;
then colors are great on plain paper ! But well, this shouldn't be the right way to do it.
The guy from Xrite doesn't believe me ! He insists that I should make the profile on plain paper if I intend to print on plain,
but this just doesn't work ! Even if that seems logical.
Please help me, I really don't have a clue there, I tried hours and hours to do it, making different profiles endlessly...
I own:
