Can anyone identify this part on a Laserjet 3330?
Hogwild
Canon D1350, Canon IP6600D
I thought this (black plastic) part and the stuff attached to it was the scanner assembly. However, Googling shows a very different looking part for the scanner assembly for a LJ3330.
Yes that is the inner parts of a scanner. The scanner motor and CCFL shows it is a scanner.
When looking for printer parts it is important to use the exact same wording as the manufacturer. A service manual and parts catalog is a great help.
Here is a service manual and parts list. See pages 246 and 247. It looks like the parts number is C9124-60103 Scanner assembly.
Googling "hp lj3330 scanner assembly" finds many strange things, for instance this that looks like a HDD mounting bracket to me. I think they attached a wrong image. I have also seen laser scanner unit which is the component that writes the document to the drum,
Hogwild
Thanks. I already tried that part number. No one has it in stock in the west.
Already have the service manual, thanks. I really just need to replace the mirror. But maybe if the entire assembly holding the mirror was cheap, I would've tried to get it. Looks like this is going in the garbage. <sad>
I'm going to try very hard never to break a mirror again.
Maybe you could find another HP AIO of the same vintage or some old Scanjet model? I think these were all CCD scanners so maybe a mirror could be found in one of these?
Here is a good explanation of the working of CCD and CIS scanners. The CCD drawing made me think HP probably used the same mirror in all Letter/A4 CCD scanners.
Hogwild
Thanks. Unfortunately, the site throws an "access denied" error.
Yes I see they blocked access to the site. I think I found the drawing of the CCD vs CIS scanners on Google:
"Besøg" means "Visit".
At least some of the article from the blocked site can be seen on linkedin. I don't know if that is any help?
I found out The Wayback Machine made a snapshot of the article before the access was restricted. Link here.
compudevices
New Printer Member
Canon i560
Yes, those are internal components of a scanner. The presence of a scanner motor and CCFL indicates that it is indeed part of a scanner assembly.
When searching for printer parts, it’s important to use the exact terminology provided by the manufacturer. Referring to a service manual or parts catalog can be very helpful in identifying the correct components.
Here is service manual and parts list (pages 246–247), the part number appears to be C9124-60103, which corresponds to the scanner assembly.
However, when searching for “hp lj3330 scanner assembly,” the results can sometimes be misleading. For example, some listings show items that resemble a hard drive mounting bracket, which suggests incorrect images may have been used. Additionally, you may come across the term “laser scanner unit,” which actually refers to the component responsible for writing the image onto the drum, not the flatbed scanner itself.
