W. Fisher
Epsons, Canons, Brother.
Fwiw, I had to remove Argyll as it was causing some USB port issues with the x-rite and Calibrite software. Seems it was scanning the USB port and the connected device when it was in operation with other software causing an issue, almost like double-profiling.
I also had some issues with my old ColorMunki Photo with the old x-rite software on Windows 11. Was getting some green cast. Seems that cleared up when I paid the $69 for the newer version 3.0.4 of the Calibrite Profiler.
Tony4597
Cheshire, UK
Epson Surecolor SC P800
I tried it. With this command, prints start shifting slightly yellow, especially noticeable on faces.Do I not need the -l flag at all in colprof for my situation? And should I keep -l 330 in targen?
I understand that you are concentrating here on producing a good paper profile, but you have not mentioned your print viewing conditions and monitor calibration which is obviously a very important factor in a colour managed workflow.
My assumption is that you are aiming at a WYSIWYG situation with your monitor matching your prints or at least close enough to make an accurate assessment of how the print will look?
To do this accurately requires the correct monitor calibration and profiling and print viewing conditions with the print illuminated ideally in the same conditions they will be when actually viewed.
When calibrating your monitor for use in soft proofing you may find that you need to choose D65 or close as this is likely to be closer to most modern printing paper whites although you may find D58 or D60 to be closer match.
The ideal monitor White Point is the one that gives a visual match to the print when illuminated by the 'correct' light source
However when producing your print profiles ICC standards assume D50 (5000k) and this should be your starting point.
Attached two images the first being the monitor conditions set to D65 and D50 as a composite with two different papers sitting underneath each monitor. The shots illuminated by daylight in both cases. While not presented as being 100% colour accurate neither monitor setting is an exact match for the paper type, however it does demonstrate the difference clearly showing the importance of this step in workflow management.
The second image is by Andrew Rodney aka Digital Dog (colour management guru). I am sure he will not mind my posting it here. This demonstrating the importance of illuminating the print correctly for evaluation.
Bottom line is that if your monitor white does not match your paper white (and to take it further contrast range) when the print lit for viewing then you have zero chance of a good print to screen match with even the most accurate ICC paper profile
To take this even further it is not unknown to have several different monitor profiles one for each type of paper in use or when working certain conditions e.g.ISO standards
Tony4597
Cheshire, UK
Yes, the problem is that Argyll installs its own driver, although you can use Device Manager to swap between the drivers if you want to use the X Rite software.
It has been documented by Graeme Gill
Using Argyll drivers with existing OEM drivers:
If you currently have applications other than Argyll accessing your USB connected instrument, then you will have to manually install the Argyll driver, and then switch back and forth between the Argyll and other drivers if you want to switch between applications.
http://www.argyllcms.com/doc/Installing_MSWindows.html
