Cleaning a ET3750 Printhead
flyboy
Canada
Epson ET-3750 + 27" iMac Retin
I did the deep cleaning a few times on the printer and the colours are still spotty, so I decided to take it out and clean it.
I saw a few YTs and then took it apart. Not too difficult, so I ran some rubbing alcohol through each colour. Still not much improvement.
Is the colour function just toast or did I just not let enough ink through it ?
You probably have air in the tubes, connect a tube to the damper and pull ink via the damper outlet with a syringe and re-insert the damper(s) into the carriage.
flyboy
Canada
Thanks Ink stained Fingers !
I found a video showing the damper and will do as you suggested. I appreciate your assistance and I honour the help in the past !
