- Jan 18, 2010
- Residing in Wicklow Ireland
I have just discovered a disastrous way to clean a 9500 print head.
I had a poor nozzle check on the red colour so I decided to try using a cleaning cartridge filled with Window cleaner and some washing up liquid in it.
It went from this …
While I was at it, the cyan was looking a bit shabby so I put in another cleaning cart in that colour too and ran one cleaning cycle then printed a nozzle check, that then had both colours missing as you would expect.
I exchanged the two cartridges with their proper colours and ran another cleaning cycle and nozzle check, it was exactly the same, and nothing appeared in the red and cyan segments.
Sort of shocked, I ran two more nozzle checks and they turned out the very same, the results were yet another print head dead due to my own stupidly and ignorance.
To this…
Now if you don’t want the same thing to happen to you then DON’T be tempted to print while you have cleaning carts installed, cleaning cycles are probably ok because the heads doesn’t fire during routine maintenance, but please remember not even a single nozzle check..
It went from this …
To this…
