The surprising truth(s) of those lux ratings in archival testing
Paul Verizzo
Sarasota, FL, USA
OK, granted, this is my "Amateur Scientist" research and view of things. Not yours? Always willing to see if I've something wrong. And, I'm sure some of you already know this, but I didn't, and I've not seen reference to what follows.
The summarized version of the varying standards of lux is handily summarized in Table II of Aardenburg's "Converting Megalux-hours of Light Exposure to estimated “Years on Display” " It's one of those (printer/ink/paper) informational earthquakes "hidden in plain sight." Sort of aware of this for years, but just in my mental background. Folks bandy those "X Years" numbers around like they are from on high.
The bottom line is simply this: Kodak, Wilhelm, and Aardenburg all use different lux levels to arrive at their conclusions! Yet, the average person or of even well informed, will seldom know this when comparing paper/ink X to paper/ink Y. To wit:
Kodak uses 120 lux, 12 hours per day
Wilhelm uses 450 lux, 12 hours per day
Aardenburg uses megalux/hours, then uses 228 lux for 12 hours per day to obtain a "years" equivalency.
Quite a range. So what's realistic?
I took my incident light meter which can give a photographic EV (Exposure Value) reading, and using an online chart from Wikipedia, converted my readings to Lux. This morning: cloudless, bright, low winter morning Florida sunlight. EV of 14 through the SE window and screen, that's 41,000 lux. Yet, Aardenburg claims such a situation should be only 10,000 lux. That's a bit more than margin of error or meter variance.
Inches to the side of the sunbeam, down to EV 6.5, about 240 lux. Step back five feet, still a well illuminated interior, and it's now EV 3.5, about 30 lux. With the afternoon SW sun blasting into the Florida room later (there's actually less light in the summertime due to roof overhang), EV 9, about 120 lux, in the indirect light against a wall. I think that this is as bright as most homes will ever see in "indirect sunlight."
To the eye, the second and third readings above are visually the same, yet have an 8:1 ratio!
Lesson 1: (I think.) That "indirect indoors" can cover a LOT of lux and lifespan difference! From 30 to 120 may be typical, still 4:1. Moving a print to a slightly different location can hugely change its fading rate.
Lesson 2: Not unreasonable to take Wilhelm's ratings and multiply them by a factor of 10 for a less than real bright indoor setting. If they say ten years at 450 lux, it's one hundred using 45 lux as an indoor realistic number. Major caveat: This is for UV only, gas fading will take place regardless unless coated or otherwise protected.
Lesson 3: This is a cousin to my "Perfection is the enemy of good enought," and "Subjectivity trumps objectivity." "The more you try to nail things down with more data, the more likely the mole will pop up again, the one you thought you whacked."
Confounders that I've thought of:
1. All the settings are for 12 hours a day. Well, the sun doesn't just instantly pop up to full strength, nor does the opposite at sundown. Most offices don't have the lights on 12 hours a day. A given "bright indoors indirect" setting may only see four hours at increased lux levels, other hours tapering to less.
2. How do the daylight flourescents that "they" use compare to natural daylight? My review of histograms of sunlight and daylight sources show that they are not even close, the fluorescents having much more UV in them. That's without even taking into account ordinary window glass cuts out most of the UVB spectrum.
ThrillaMozilla
Yes, I'm sure that there is tremendous variation. Mark McCormick says that with ordinary display you might have detectable fading within three years (I don't know where the reference is). The Hat posted some images that I believe show slight fading of cyan after 3 1/2 years ( http://www.printerknowledge.com/threads/why-ink-and-lighting-matter.9150/#post-71819 ). Somebody else on this forum reported severe fading of wedding photos on a desk under fluorescent light. I myself observed complete fading of color images on paper stored in a paper bag after one year ( http://www.printerknowledge.com/threads/why-ink-and-lighting-matter.9150/#post-71819 ). I believe the fading was due to a compact fluorescent light, but in any case, it was due to light, not gas. I have a lot of paper CD labels that are exposed to light. Since I make CDs for other people as well, that convinced me that I need to pay careful attention to stability of ink.
Paul Verizzo
Sarasota, FL, USA
Indeed, it seems that the only constant is inconsistency! I recall Hat's posting and yours. Wouldn't most CD's be stored in the dark? At least most of the time?
One thing I noticed perusing the Aardenburg results is that most of the non-OEM papers really sucked. Perhaps because most of the ones tested were "artsy" finishes. Canvas, tapestry, old driftwood (I jest.) Side note opinion (Of which I have many, you've surely noted.) "Artsy" finishes do not make a print art, just like archival processing in the wet darkroom doesn't. All canvas for painting is first covered with material to make the surface paint impenetrable and...........eliminate the texture.
Even within a paper family, like Canon's, there is huge lifespan variability, according to them. I tried to find the URL with that info, but couldn't.
ThrillaMozilla
No. Most CD racks keep the CDs out in the light. And it's the paper inside the case, with artwork, etc., that fades so fast. And CD media retard fading somewhat, just like photo paper. Even so, I certainly don't want the CD label to fade either. And since I make CDs and DVDs for other people, I have no control over how they are stored.
I tested an old sample of the swelling type of HP Premium Plus paper. Surprisingly, the ink was not absorbed well, and it gave rather little fading protection. In fact, it's completely unsuitable for my printer, and it's not on HP's list of suitable papers. You really have to test stuff to find out.
Paul Verizzo
Sarasota, FL, USA
Thanks for the answer. I haven't had a CD rack in some 15 years, and in fact, never use CD's at all for any reason whatsoever for a long time now. The CD's and DVD's that I do have live in, for the most part, nylon internally sleeved cases. No styrene case. Lots of discs in a small package, easily transported. Grab 'n go.
The CD surely is the shortest lived music media since the original Edison wax tube. Twenty years? With all the angst that many of us went through trying to learn what media had the longest life span, it's all been made mute by super cheap digital storage. Sharing? Email, cloud, thumbdrive, etc. Quite a few laptops (Mac?) don't even come with a CD/DVD drive anymore.
From my research just the other day, the PLUS version of HP Premium is microporous, although that would be at odds with your experience. Swellable papers, of course, are better at preventing gas fading, I don't think there is light fading superiority.
ThrillaMozilla
I haven't had a CD rack in some 15 years.... The CD's and DVD's that I do have live in, for the most part, nylon internally sleeved cases.
The supplementary information and artwork are essential content, and paper is often the most practical choice for that. While I'm moving away from paper somewhat, I'm not going to start using disappearing ink. After all, I don't want the art on the CD to fade either.
Please, let's not get off the subject of printing. I am aware that no medium is permanent, and that certainly includes hard drives and flash drives. I have use good materials and have backups for anything I have produced. According to the alarmists, my entire collection should have faded into oblivion 20 years ago, but so far I have not experienced any problems. I have, however, experienced problems with fading of photos, and some of them are irreplaceable.
I would like to switch to another medium, but my friends want DVDs because that that's the only medium that I can distribute that everyone can play. And if it's not DVDs, it would be BlueRay discs.
From my research just the other day, the PLUS version of HP Premium is microporous....
It has been reported in this forum that HP changed the formulation, but in any case, I used a sample from 10 or 15 years ago, and it was swellable paper.
Paul Verizzo
Sarasota, FL, USA
Wasn't on "the subject of printing." Just making observations about the short life of the music CD format. May your CD prints last many times longer!
