- Jan 18, 2010
- Residing in Wicklow Ireland
To lose one print head is unfortunate but to lose three, well I don’t think there are any words to describe or made up for this situation yet.
The two most common factors here are the printer and you, so what exactly are you doing wrong to have so much bad luck with one of the last best known Canon printers around.
What type of cartridges are you using , are they new OEM cartridges, aftermarket cartridges, 3rd party refillable cartridges or OEM cartridges that you refill yourself. (Give details)
The answer to your problems has to be down to the cartridges you are using because print heads normally just don’t fail out of the blue without just cause, well not three in a row anyway.
Ink starvation is usually the biggest contributor to premature death in nearly all print heads, so continuing to print while there is inadequate ink flow inside the print head will cause it to fail quite rapidly depending on the demands you put on it.
The information you are giving us is a bit confusing so we don’t know how many printers you have and therefore can’t give you a very good answer to your problem.
Can you start again but this time give details of your current printers history and try to explain only this latest printers problems from the very beginning please..
