- Jan 18, 2010
- Residing in Wicklow Ireland
Its First victim me !
I have been using these cartridges for the past year or so (Not in a Pro100) and only last week did a problem arise for me, was it caused by the Yellow CLI-42 cartridge I don’t honestly know but my gut instinct would suggest yes, conspiracy theory or otherwise.
I don’t like airing my misfortunes openly and boy I’ve had quite a few lately but I feel it’s vitally important that others should be aware of things that can go bump in the night.
The print head on my converted iP4700 went bang last week, massive failure in the yellow !, yes I said the yellow and for no apparent or obvious reason, just coincidently it happened that I was using one of these rebadged CLI42 carts, it has been refilled five times.
I first put the problem down to using oversize cartridges but was later reassured by@Tudor that this was not the cause, so it just must have been the age of the print head, (Expired) till I was purging all of the cartridges that I had used.
Here is the CLI-42 cartridge purged of all ink with just clean clear water in both the reservoir and sponge sides, (Completely Full) the sponge has always remained stained with ink which is unlike every other yellow cartridge that I have purged in the past.
So here is the question:- Was @mikling right to bring this to our attention, is there an issue with OEM and 3rd party yellow inks mixing, well I would say absolutely, especially in my case anyway. (To darn late)
So now its decision time, do all you guys just ignore this helpful advice given free or do you act upon it and use an alternative CLI-8 cartridge till you can remove all of the remaining ink inside your CLI-42 cartridges, it will save a perfectly good print head if you do.
I will post later on how to remove the remaining yellow out of the cartridge and make it safe to use again..
I would prefer that everybody make up their own minds on this. Is there a problem or not ?.
