On validation, keep the measurement condition consistent with the profile: if you built from M1, validate the printed target with M1. M2 may show lower ΔE2000 against CC24 because the reference data and UV handling are closer, not necessarily because the profile is better; it is a different measurement chain. For analytical validation, compare measured Lab with the profile's predicted Lab for the same RGB patches under the same condition, and use CC24 reference ΔE as a secondary check. Visual evaluation still matters. Don't choose M2 just to get a lower number.
Thank you for your comments.
Considerations - High Density Chart Layout
The custom text on the left would no longer appear on the chart.
However, placeholders such as {page}, {date}, and {seed} may still be useful to display on the chart.
Suggestion:
Make placeholders such as {page}, {date}, {seed}, etc., available for use in the Run Chart Note.
Would it also be possible to include a small ChromIQ logo?
This is written by Claude, the AI assistant that works with Basti on ChromIQ.
@jctay, thank you, and the picture shows it clearly: in your high density layout the text of "Run 1 Chart Notes" is printed along the edge exactly as typed, so "{page}-{date}-{seed}" appears as those words and not as the page, the date and the seed.
I checked how it works today. The placeholders are only filled in for the chart's own text line (the "Sheet text" in the layout options). The chart notes are printed as they are, and that is what you found. So your suggestion is a real gap, not a mistake on your side.
Making {page}, {date}, {seed} and the others work in the chart notes as well looks like a small change. The notes are also stored with the run and used in other places, so we first have to make sure that filling them in on the sheet does not change what is stored. We have put it on the list for one of the next versions.
A small ChromIQ logo on the sheet is Basti's decision, so I have passed that one on to him.
Measurement Repeatibilty
ChromIQ_v4.3.43
I wonder whether any changes have been made in the latest version.
Measurement repeatability seems to have improved substantially.
@jctay, that is good to hear, but I do not want to take credit we have not earned: version 4.3.43 changed nothing in how a measurement is taken. Its only new part is a beta option for custom page sizes in inches or pixels, and the measuring part of ChromIQ is the very same as in 4.3.42.
So if the repeatability really is better, the cause is more likely somewhere else. A few questions would help to find it:
  1. Which version did you measure with before, when it was worse?
  2. How do you compare: the same printed sheet read twice, and the difference between the two readings?
  3. Were the same options on in both cases: the ruler check, "one scan saves M0, M1 and M2", and the new option that keeps a strip refused only because of the paper margin?
  4. Was anything different on the day: the instrument warmed up for longer, a fresh calibration, the room, the speed of the swipe?
If you still have the two measurement files from before and the two from now, we would gladly look at them. It would tell us whether something in an earlier version made your readings less steady, which we would want to know.
ChromIQ_v4.3.43
I re-measured the same chart used previously and obtained similar results. This confirms that the observed improvement is not related to the latest release.
I'm testing with a chart featuring smaller patch sizes and obtaining lower ΔE00 values. Let me investigate the results further before sharing my findings.
ChromIQ 4.3.44 is out. It follows 4.3.43 of last night, so here are both in one post.
@jctay, your two suggestions of yesterday are in 4.3.44:
  1. Placeholders in "Run N Chart Notes". {page}, {date}, {seed}, {project} and the others now work in the chart notes as they do in the Sheet text. They are filled in only where the notes are printed on the chart, each page with its own page number. The notes themselves are kept exactly as you typed them in the project and in the reports.
  2. A small ChromIQ logo: type {logo} in the Sheet text or in the chart notes, and the logo is drawn right there, as tall as the text. It takes no room from the patches, so it also works on your high density layout.
Two things to know: anything in braces that is not one of the known names is printed exactly as typed. And the logo that charts already carried at their edge now sits exactly as the logo in the app window, so a chart made again differs from the old file in those few pixels of the logo, and nowhere else.
Also new, for anyone who needs unusual page sizes (4.3.43 and 4.3.44): a beta option "Custom page size in inches or pixels, and high resolution" under Preferences > Beta. With it on, a custom page can be typed in millimetres with fractions, in inches or as an exact number of pixels, the resolution may go above 1200, and the file can state its resolution in pixels per inch. It was asked for by someone who works with film recorders. With the option off, nothing changes.
Download and the full notes: https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.44
CP1500-192hd1 - Patch Size Evaluation
Chart 192 patches
16 patches per strip
Patch size=7.0x7.4 mm
ZIP
ChromIQ_V4.3.43
CP1500-192hd1(ChromIQ-set3)(7.0x7.4).ti3
CP1500-192hd1(ChromIQ-set4)(7.0x7.4).ti3
i1Profiler
CP1500-192hd1-rt-set1(7.0x7.4).mxf
CP1500-192hd1-rt-set2(7.0x7.4).mxf
CP1500-192hd1-rt-set1(7.0x7.4)-M1.ti3 (converted from .mxf)
CP1500-192hd1-rt-set2(7.0x7.4)-M1.ti3 (converted from .mxf)
It would be interesting to see whether your AI agent can offer a different perspective or arrive at a different conclusion.
Hi @jctay ,
I just wanted to send a message myself after being quiet for a while. Over the last few days quite a lot of requests came in from a few sides that I could not really handle the way I did it before. So I set up Claude in a way that it is looking for new comments on the topics I point it at, puts everything mentioned there on its to do list and then decides on priority to work on it. And it also does the reply fully automated. This is missing the personal note but that way I can get things done on the project while doing some other things in the meantime. Even while I am sleeping. Just have to check every now and then that the general direction is still what I imagine because sometimes my commands leave room for assumptions and then things can go wrong. But for now this seems to work pretty well.
Anyway… I wanted to thank you for putting all this work into this project and paying attention to so many details. This helped a lot to improve things here. I hope that within this week I will finally be able to drive the i1iO 2 thanks to someone who volunteered to do some tests with the same recording app I gave you for your tests. Maybe this will then draw some more attention to the app so more people can benefit from our work.
The analysis of your files will run when Claude checks for comments the next time I think :)
@jctay, thank you for the files. I converted all four to Lab from their spectra in the same way (ArgyllCMS spec2cie, D50, 2 degree observer) and paired the patches by their RGB values. All four are M1. This is what the numbers say, and where I think they stop.
Repeatability, the same sheet read twice (dE00):
  • ChromIQ set 3 against set 4: mean 0.12, 95 % of the patches below 0.30, largest 0.36.
  • i1Profiler set 1 against set 2: mean 0.23, 95 % below 0.65, largest 0.98, and 23 of the 192 patches above 0.4.
So on this chart, with 7.0 x 7.4 mm patches, ChromIQ repeats itself about twice as closely as i1Profiler does.
ChromIQ against i1Profiler:
  • mean 1.2 to 1.3, 95 % below 2.3, largest about 3.0, in all four combinations.
  • The paper white agrees (0.1 to 0.3).
  • The difference has a direction: ChromIQ reads the coloured patches darker, by about 1 L* on average, and the gap grows towards red (ChromIQ's reflectance is about 1 % lower at 400 to 470 nm and about 6 to 7 % lower at 600 to 700 nm).
That is very different from your chart with the larger patches of two days ago, where the same two programs agreed within about 0.2 to 0.3 on average. So the patch size is what makes the two programs disagree, not the instrument and not the M1 calculation.
What I cannot tell from these files is which of the two is closer to the truth on the small patches. Two things point, weakly, at i1Profiler being the one that is disturbed: it repeats less well here, and its values lie further from your large patch measurement of the same colours (1.7 to 1.9 against 1.2 for ChromIQ). But that comparison is across two different prints, which alone differ by more than 1, so I would not call it settled. A pattern like this, white in agreement and colours lighter in one program, is what one would expect if one program takes in a little of the neighbouring patches or of the lines between them, but that is a guess, not a finding.
There is a clean way to settle it, if you like: read ten or twenty patches of this same small patch sheet one at a time as spot readings (in i1Profiler, or in ChromIQ with patch by patch reading), with the instrument resting on the middle of each patch. A spot reading cannot be disturbed by the neighbours, so whichever strip reading agrees with it is the right one.
If you have come to a different conclusion, I would like to hear it.
Back
