Pro-100 - No power to the printhead after bonehead move on my part
samboy
Canon PIXMA Pro-100
Ok, can't believe I'm already having to take the top cover off my 2nd one of these printers. See picture below. I haven't found the spring yet, but I haven't looked terribly hard either. I did accidentally pop the tiny spring off next to the purple arrow, but hopefully I got that situated. The white gear doesn't exactly move freely, but it will move with some force. The motion is smooth when forced so I'm not sure if that's an issue or not. Does anything jump out at anyone in the photo? Seriously, thank you for this
OK, does the purge unit move up and down and the wiper blade slide back and forth, when you rotate the white gear.. But you will need to find that missing spring, before powering the printer back on again..
samboy
Canon PIXMA Pro-100
Nothing appears to be happening when I move the white gear. I still haven't found that spring either. Any idea how I can investigate that gear a little more?
