Canon Pro-200 not printing PC/M/Y/PM
Tambotan
Canon Pro-200
Hi all, first time poster
I bought myself a Pro-200 a few years ago, used it a bit and then put it in storage without thinking about it too much. Fast forward to last week when I finally decided to stump up the extortionate amount needed to replace all the inks. I'm sure you can guess what is coming next, I ran a nozzle check and none of the photo printing nozzles were working properly
I found what I thought was a helpful Youtube video and have just spent the last 2 days cleaning the print head with a mix of distilled water/isopropanol alcohol and household ammonia as suggested. Lots of old ink came out and eventually the little sponges where the cartridges fit in all went grey and no more ink was coming out.
I dried it all out over 24hrs and excitedly printed a new nozzle check (after running a clean 2x as I saw suggested somewhere)
Hmm 🤦‍♂️
I also tried a deep clean of just those colours but it didn't help.
I presume at this point the print head is a write off but before I spent the, frankly unbelievably, £170 for a replacement can anyone tell me please if that is likely to fix the issue?
I'd hate to spend £120 on ink and then another £170 on a print head and still not be able to print some pictures off for my daughter!
Many thanks for any help!
Ollie
*EDIT* Sorry I should have said, the inks I bought were genuine. I bought the whole set so every cartridge has been replaced
Ollie
Try removing all the carts and print head and placing the print head in a small bowl of warm water with some fairy liquid in it, let it stand for several hours and then repeat with warm water and the washing up liquid again.
Leave it overnight and then in the morning dry out the head giving it a good shaking and possibly using a hair dryer on it for a few minutes, concentrating on the back of the head where the electronics are. Don’t over heat..
While you have the head out splash or spray the purge unit with a lot of W5 window cleaner, give the whole area a good splashing then using kitchen paper towels mop up as much as you can, then this is the important bit, flood both pads with window cleaner..
Now install the head and cartridges and let the printer do its own routine and then when it stops, run one nozzle check and see how much different it is compared to your previous ones, it should be a lot better, if not completely 100% clear, then run a normal head clean and let the printer sit for half an hour..
Your next nozzle check should be perfect.. :weee
P.S. Keep ammonia away from the head…
Tambotan
Canon Pro-200
Hi there,
Thanks ever so much for coming back to me! I looked into it on Google but I couldn't find out what the "purge unit" is? I could see that as a spare part for Pro 2000s etc. but I have a Pro-200. Would you mind pointing me to what I need to squirt with W5 window cleaner please? Is it this thing (found in someone else's post on the Canon site)
If so, is there an easy way to get to it because it would be quite difficult to get in there on mine for some reason, it is tucked away in a corner and I'm not sure how I would squirt stuff onto it without getting it everywhere. I didn't want to start pulling on it and damage something. I couldn't see mention of it in the manual.
Many thanks
Ollie
Tambotan
Canon Pro-200
Sorry, here's a picture from my actual printer. Hopefully you can see the white unit would be quite difficult to get to, unless I'm missing a trick?
That black cover above it with CLI-65 in white on it would be completely in the way. I guess I might be able to soak a cloth and then poke it in there?
Cheers
Ollie
