Canon TS8251 - intermittent 5011 error
Glomgold
MG6650, MP610
I got a 5011 error out of the blue. The error appears a few seconds after I power it on, the carriage doesn't move, sometimes it tries to move right before the error appears.
I have had it running normally 2-3 times, when it starts up normally it's nothing wrong, no strange sounds.
There was quite a bit of ink in the area around the pads, I've cleaned this up.
The encoder (?) strip is clean as far as I can see.
I cleaned a metal plate facing forwards, the carriage moves along the plate, it was full of ink.
No paper jams.
Nothing loose that I can see or hear when I tilt the printer to all sides.
I've had it disconnected from power for days etc.
I'm planning to remove some panels to get a better look at things, but I really don't know what I'm supposed to look for.
There are no service manuals available for the TS8251, but service manuals for other AIO printers suggest a scanner error.
Druckerchannel.de has an article with lists of Canon error codes here. You can use Google translate or other translator if you don't read German.
Here is a clip translated to English:
Glomgold
MG6650, MP610
Thank you.
The scanner moves ever so slightly when I turn it on. It's been standing in one place since new, I'll try an disconnect it.
Glomgold
MG6650, MP610
I've disassembled it as much as I dared, cleaned the encoder strip, reseated some ribbon cables. No change, it could be the scanner.
The scanner only moves ever so slightly, about a centimeter, the error appears when it has gone back. I don't see anything that's broken.
Glomgold
MG6650, MP610
Did you remove the packing screws to free up the scanner..
I'm not sure I understand. The scanner has worked before, I don't recall removing any screws.
I have a TS8351a, which i think is very similar if not identical to the TS8251a. It has got no scanner lock or locking screws.
Glomgold
MG6650, MP610
Extremely annoying to have to throw out a printer for this kind of error. The error code is so generic, could be a hardware problem too.
Glomgold
MG6650, MP610
The carriage moves freely, I don't see anything obvious wrong. At this point it's not important that I will be able to put it together again, should I try to remove the whole carriage and clean it on the backside?
donaldolsen
United States
Canon i560
No paper jams.
Usually 5011 errors are due to the carriage or a sensor. Check to see if anything is in the path of the carriage or if there is any ink around the sensors or cables.
