- Dec 27, 2014
- Germany
for which format do you need the borderless option - 10 x 15 cm or A4 ? This narrrows down the
model options pretty much. You may look to an Epson WF-2010W or WF-2110W as the successor, it's a printer with cartridges and pigment ink. Refill is easily possible with refill cartdridges with auto reset chips.
The ET-1810 is pretty much the same printer hardware as an ecotank model, but runs with dye inks and does borderless only for 10x15 cm. You may run this printer with pigment inks as well.
Borderlless printing a typical feature of photo printers at the high-end range like the Canon Pro 300 or Epson P700.
