- Thread starter
- #11
knowing
- Oct 24, 2025
- HP CLJ5550, Brother MFC-9460
Thank you for creating this script. I had an X-Rite i1 Studio (same device as the Colormunki) for a few years now and only ever used it for display calibration and profiling with DisplayCal as a GUI for Argyll.
I never got the printer calibration to work because the terminal commands for Argyll were a little bit too much for me to handle. But with your script I managed to create my first selfmade printer profile today.
For my first attempt I used menu option 1 and created a target from scratch. This worked perfectly fine.
My first issue was a bug in the ColorSync Utility. The option to print the image as a target is greyed out by default. A google search helped me to work around it. I had to go to the printers color settings and assign any color profile to the image. Then the ColorSync Utility allowed me to select the option to print it as a target. I printed the targets and let them dry. Then I tried to read the patches without any tool as a guide. This did not work very well. I got a lot of errors like "you probably read line AZ instead of A" or "too many patches recognized" or "not enough patches recognized" or "unexpectedly high deviation" (those weren't the exact words but it was somewhat similar). So this first attempt with 4 A4 sheets took me quite a long time and the result was not great.
But this was completely my fault because I wasn't used to handle the device properly.
For my second attempt I used the target you added in v 1.2.0 because you mentioned it in your release notes. I also remembered that a friend of mine 3D printed a guide for the i1 Studio for me. It is not the best quality but it made the reading process so much easier and faster and I got only a few error messages. The profile turned out pretty good.
The image on the top is printed with the default settings of my Epson ET8550, the middle one with the profile I got on my first try (better colors but posterization in the faces) and the one on the bottom is the final result. I am very happy with it. So thanks again!
Best regards
Awesome!
Thank you, itsab1989, for your feedback! You are the first to give some word about using the script. I really appreciate it!
Cheers,
K
