Am I defecting to Canon ?
andy1978
T2100
Thanks for your previous input!
I found the chips for T2100 cartridges on AliExpress for £35 per set, but with VAT and shipping, the total comes to £50 just for the chips. At this point, it's becoming less and less worth the hassle, especially considering that third-party cartridges in the UK cost around £100. Since those are pigment inks, I'm wondering if it's even worth bothering with refilling via syringes.
On the other hand, I looked into the Epson 3100X Megatank and went through all your previous comments on it. From what I understand, the best option would be to replace Epson’s original dye inks with Canon GI-53 dye inks.
I have a question about switching between dye and pigment inks. If I start using dye ink, do I need to fully empty the cartridges before switching to pigment, or can I mix them while printing? Is there a specific cleaning procedure, like flushing the printhead with a special solution, before switching to pigment ink?
Also, I’m still unsure about the actual difference in print quality between dye and pigment inks for photo printing. I know pigment ink is more durable and doesn’t fade as easily in sunlight, but is the difference that significant in real-world use?
I’m also considering the Canon TC-20 and using dye inks (GI-53) from the start instead of pigment. Since I’ll only be printing on 24” canvas rolls (no sheet feeding), this setup might make sense. But I’m not sure if it’s the right approach.
To be honest, I tend to get frustrated easily with finicky printers, and if the TC-20 gives me too much trouble, I might just throw it out the window (hopefully, it's heavy enough that I can’t lift it). Jokes aside, I’m still debating between the Canon TC-20 and Epson. I called a company in the UK today, and they said Epson produces better-looking prints than Canon. But I don’t need museum-grade Rembrandt reproductions—just good-quality prints.
Based on what Keith showed in his video, Canon doesn’t seem like a bad option. Maybe I should just order it on Amazon, test it for 30 days, and return it if it doesn’t work for me.
Yesterday, I received canvas samples from a company, ranging in thickness from 260 to 360 gsm (260, 280, 300, 350, 360 gsm). I’ve ordered a caliper on eBay to measure the exact thickness, as it provides accuracy down to 0.01 mm. I’ll check whether I can print on canvases up to 0.27–0.28 mm thick.
I watched a video from a woman in the U.S. who prints on the Epson T2100 (which is called the T2170 there, but it’s the same model). She prints 24-inch canvas rolls, around 300 gsm, without any issues and is very happy with both the printer and the print quality—whether on canvas or photo paper. She loads a full 30-meter roll of canvas, and it works flawlessly.
Interestingly, whenever I talk to companies about printing on canvas, they all shake their heads and say this printer is completely unsuitable for it. Yet, people are successfully printing on it and getting great results. It feels like a bit of a scam—everyone insists this printer is only for CAD and engineering prints, then tries to steer you toward a £5,000 printer instead of a £500–600 one. That’s just the reality of the market, unfortunatey.
I understand that it is difficult for you to make the right printer selection: both the TC-20 and the T3100X are oriented to CAD/poster printing jobs - the word 'photo printing' is nowhere mentioned in the user documentation - not at all - thjis is intentionally but let's not talk about marketing. Both printer types do a pretty good job printing photos. The pixels and inkdots you are printing just don't know if you print a drawing or a photo. There is one limitation that the gamut - the range of printable colors - is slightly smaller than with the 8 or 10 ink engines. But if that's your concern you would need to test some other papers, it's the papers as well which make a good print, and not just the inks and the printer.
You may have a look to the Canon TM240, as well budget priced like the TC-20, that printer supports a wider range of roll papers - there is no roll diameter limit, and the paper thickness ranges from 0.07 mm to 0.8 mm, you may see it in the user manual on page 301
https://gdlp01.c-wss.com/gds/9/0300...5x_5340_525x_5240_OnlineManual_Win_EN_V02.pdf
I had the T2100 for a short while, if you want to do refill you need the one-time chips which are pretty expensive, and I don' like the refill fiddling that much, so it is a printer for a low volume activity. The overall printer handling, print quality etc , all that is very good. The T3100X Ecotank version is technically the alternative. You need to calculate when you do refill and can reach the break even point.
Canvas paper - I don't have any experience with such papers, but I assume that it'll be like always - go and test papers from various suppiers and get your own opinion - some may have a sample pack of their papers or offer some of their papers both as roll or sheet material. I wouldn't give much on general statements. Paper testing can be done as well with sheet paper, you won't need rolls.
Yes, you could use the GI-53 dye inks instead in the TC-20, but I don't see a benefit really. It's very much a question how long - days - weeks months - years prints are exposed to light, that can even be room light, light from fluorescent lamps can be a killer. But if you print posters for the next sales out action such prints are used just for a short time etc - so again - it very much depends on the actual situation. And don't forget that prints with dye inks are prone to humidity which could be an issue on an open construction site. You may look as well to the T54C inks as a dye substitute for the T3100X, those Ultrachrome inks are the inks with the longest durability, better than the inks Epson is shipping with T3100X originally.
It is easier to move from dye to pigment inks as I mentioned, I would not flush the ink system but reinstall the driver and let the printer do an ink charge after printing down and emptying the old ink. But keep in mind that you may impact your warranty status in case of a problem. So I would discourage you to do it at this time.
andy1978
T2100
Subject: Ink Options for Epson T2100 & Canon TC-20
Hi,
Thanks for your detailed response! Yes, I found the T54C inks in the UK at a reasonable price—£16 per bottle. The only issue is that while regular colors (cyan, magenta, and yellow) are available, there are also light cyan and light magenta options. I assume I should just stick to the standard inks and replace the light colors with regular ones in the Epson 3100x correct?
Also, what would you recommend for the Canon TC-20? Are there any good third-party pigment inks available? I came across Farbenwerk in Germany, and their inks seem to have a solid reputation. I was considering using their PIGMERA C1 inks, which are designed for Canon printers like the iPF1100. They’re reasonably priced, and they provide ICC profiles for their inks on their website.
I’d love to hear your opinion on Canon-compatible pigment and dye inks. Does Canon offer any good pigment alternatives that don’t cost £220 per set?
By the way, I also have a Canon G650 for personal use, and I think it prints photos beautifully with the original GI-53 inks. But how do these inks compare to Epson’s T54C? Are they of similar quality?
Which inks for which printer are you looking for ? We have discussed so many variations already.
If I look to the TC-20 the Chinese substitutes for the PFI-050 Canon pigment inks could be an option
https://de.aliexpress.com/item/1005...st_main.5.33715c5fO8S0Ow&gatewayAdapt=glo2deu
The bottles are keyed at the top, so you don't need to swap the inks into the orginal bottles.
Yes, you can use other compatible inks - Farbenwerk or other companies like Inktec - you just would need to be clear which type you would use for the black ink - the PFI-050 black is universal for matte and glossy papers -other inks are not so it wouold be advisable to stay with the PFI-050 black regardless which other inks you would choose.
The GI-53 Canon and the Epson 106, 114 and T54C are about quite similar in performance , with a small benefit for the T54C inks, The GI-53 inks can print on any Epson printer but not the other way around. The T3100X only needs the CMYK inks - you don't need the light inks and just don't order them.
Farbenwerk is doing quite a lot of icc-profiles for their inks, but you don't know if that includes your paper(s).
I don't have any experience with the Canon pigment inks for their Megatank printers of the GX model series, they most likely will print as well and could be another option, but again with the PFI-050 for the black pigment ink.
So I think you are in a quite comfortable position with that choice of inks.
andy1978
T2100
I’m in a pretty comfortable situation, so to sum up: for the Canon TC-20, I could use Farbenwerk pigment inks, keeping the original Canon black ink. As for the Epson, I would go with the TC-54C inks since they are dye-based and also made by Epson, so they likely wouldn’t void the warranty. I think this is the best option.
Thank you for your support – it has been incredibly helpful.
I measured the canvas with a weight of 280 GSM, and its thickness is 0.34 mm, which falls within the range supported by the printer. The manufacturer specifies a slightly higher maximum thickness, but I know the printer can handle it without any issues. If it were 0.4 mm, I would have to reconsider, but 0.34 mm is perfectly fine – I’ve seen many users printing on canvas with these models.
Thanks again for your help! If anything comes up, I’ll reach out. I’ll also try to share my opinion on one of these printers – either the Canon or the Epson – as it might be useful for someone.
Thanks for your feedback; please let us know your experience with your new printer whatever model that will be; that will most likely vary between different users.
I'm just reading that Canon has presented a successor to the TC-20 printer - it's the Prograph TC-21 , it looks the same as the TC-20, the technical data are almost the same - I see differences here
- the printer now comes with an adjustable display/user panel
- the printer offer almost borderless printing - top/bottom zero margin - left/right 0.5 mm margin
I haven't seen pricing yet, I expect it close to the TC-20 pricing
There is another model variation - the TC-21M with an A4 scanner
It'll be interesting to see whether and how Epson will react
https://www.canon-europe.com/press-...-21-and-tc-21m-large-format-desktop-printers/
The fixed panel was the main reason for me to give the printer to a friend of mine, the panel was in a position that the display could not be read.
It's now about a year ago that I got a replacement for my old Epson Pro 7600 24 inch printer which I dumped due to some age related problems after about 20 years of operation.
I tested both the Canon TC-20 and the Epson T3100 and T3100 which are quite similar in functionality - 24" roll printing with a cutter and an additional sheet feeder for A4 - A3 paper, The TC-20 and T3100 are running on pigment inks, the T3100X originally with dye inks - the T3100 with pigment ink cartridges.
Epson and Canon are playing different pricing models for these printers
- Canon for the TC-20 and TC-21 successor - low printer price and high bottled ink prices
TC-20 660€ and the TC-21 for 700€ , 70ml ink bottles at 50€
Epson the same for the T3100 - low pinter price and high priced pigment ink cartridges
The T3100 runs at about 1150€ - the T40C cartridges pigmented for 50€ for 50ml
Epson for the T3100X - high printer price and low priced ink bottles
the T3100X Ecotank is priced at about 2000€, for ink bottles with 140ml for 25€.
I'm doing refill for the T3100X with pigment inks left over from the old Pro 7600, I don't have problems with printing, ink refill handling etc at all, barely any missing nozzles etc, I'm printing, regularly, about every day, mainly via the sheet feeder.
Both the T3100X and the TC-20/21 are just using one black ink, the T3100X Epson driver omits the black ink if glossy type media are selected, similar to Epson's approach since a long time - no prints with the black ink on all 4-color pigment ink printers.
Canon's approach is different - they use a black ink which prints on matte, coated, uncoated and glossy type papers alike which is different to Epson's approach. I briefly tested the PFI-050 ink of the TC-20/21 models in my old WF-2010W desktop printer with cartridges which easily can be swapped with different inks for tests. Canon inks print in Epson printers w/o problem. This PFI-050 ink is a kind of compromise ink overall - but really not bad. The black on glossy type papers is much darker and neutral than Epson's mix of the CMY inks.
You may think and rather use a photo black Epson ink in a T3100X but use the matte paper setting in the driver - the Canon PFI-50 black is almost as black as a Epson photo black. But if you now print with the photo black on uncoated paper the black level of a Epson photo black ink is not as black as the Canon ink - the Canon black ink is performing very well - as a compromise ink on matte and glossy papers. I'm using this PFI-050 ink in my T3100X w/o problems and good performance.
The Canon GI-56 pigment black is used a similar way on the Canon GX... series (home)office type and may be used in place of the PFI-050 bottles. I don't see much difference, the gloss of dark prints on glossy papers may look slightly different, but every ink/paper combination performs different anyway, and the effect is not specifically related to these black inks. The GI-56 inks are charged for about 11€ for 170ml which is a significant price drop vs. the other inks above. You may use as well the CMY GI-56 inks in an Epson printer but I didn't test the look and gamut of these inks at this time.
So let me conclude this posting - the T3100X performs well - with no hiccups or irritating or repeating errors at this time.
I'm now running the Epson T3100X since a year, prints are very good and I didn't encounter any problems so far; I used about 2 - 3 130 ml refills varying by color. I did not encounter problems or functional issues beyond those which got discussed in this thread before. And I have an answer to the last question if I would have a reason to buy such printer again - I probably would rather choose the
Canon TC-20/21 instead - simply for pricing reasons of the printer unit itself, the T3100X and the TC-20 are pretty similar with their features.
Latest posts
