Canon Imageprograf TC 21 /Lucia TD inks and harvesting inks from 300ml/ 700 ml cartridges
I wouldn't expect some ink to be perfect, but suiting the requirements and I would not expect technical problems with the inks in discussion, the Canon GX... series printers and printers like the TC20/21 work with very similar droplet sizes, so the physics to get the ink droplet onto the paper through the printhead nozzles are very similar for 4 - 5 picolitres. it may be different with the photo printers running smaller droplets through smaller nozzles.
As mentioned before the TC20 is not advertised as a photoprinter which may have as well inmpact onto other
properties like bronzing or gloss differentials which are very much visible effects caused by a particular paper/ink combination. It is quite possible that one ink/paper combination - mainly glossy or silk type papers - may look (almost) perfect, and prints with the same ink, but another paper - another brand - may just look terrible, or vice versa - everything is possible. That's the point where Canon comes in with its gloss optimizer reducing such
effects very much. Such gloss optimizer is part of the inksets of their photoprinters but no office type printer has it - you have to live with it - Canon does not tell you to print photos with an office printer . It may be good enough for you - that's o.k. but you are effectively running the printer out of spec. That's the reason I mention to you to run some tests so that you can find the best looking combination of inks and papers. And I would think that you
wouldn't care about bronzing in some print if that's technical drawing of some machine or construction elements.
I had a TC20, the prints are good, very good - as good as they can be with a 4 color printer and 5 pl droplets.
hdtvjeff
My goal is to print life-site cutouts of people I know that or maybe 60 long. Perfection is not a requirement. I have Canon image prograf 1000s that I will only use with OEM ink
I have used CMYK printers in the past with dye based and pigment as well basically with Epson
I will take the plunge and experiment with the GI26 inks I have roll paper in gloss and matte
The glasses from a company called RC and the matte is from Canon
The GI26 inks coming 167 ml for black and 137 ml CMY
Thank you for all your help!
hdtvjeff
I wouldn't expect some ink to be perfect, but suiting the requirements and I would not expect technical problems with the inks in discussion, the Canon GX... series printers and printers like the TC20/21 work with very similar droplet sizes, so the physics to the ink droplet onto the paper through the printhead nozzles are very similar for 4 - 5 picolitres. it may be different with the photo printers running smaller droplets through smaller nozzles.
Also I will be buying Canon OEM GI 26 not third party
It is not clear to me what printer must be refilled, but I buy GI-56 bottles to refill the cartridges of my Maxify.
This works flawlessly (all Maxify's have the same printhead) but I had mixed results with Canon large format Lucia inks (BK is fine, but C,M an Y tend to clog).
hdtvjeff
I am looking to refill the CMYK Canon ImagePrograf TC 21 with CMYK ink which is also pigmented but not Lucia based with regular OEM pigment ink from GI 26 bottles via siphon method
ThrillaMozilla
AI is just summarizing what one or more persons has written on the Internet. It might be right or it might be wrong. It's possible that AI might be coaxed to reveal its sources so you may be able to evaluate the accuracy of the information.
