Epson p700 print head alignment problem
Lynnea1941
Epson P700
I have done several print head alignment sheets. The first row just never changes. It doesn't matter what number I use for the "best" square, the result is always the same and all the squares look alight.
I am in email conversation with Tech Support, and I will be doing my third round doing the print alignment. I do see changes in several rows, just not the first row.
Any suggestions?
Thanks.
thebestcpu
Printing Ninja
Epson SC P900
Hi @Lynnea1941
It might be helpful to share a copy of the alignment results page
Just a suggestion
John Wheeler
Lynnea1941
Epson P700
Here are the three alignments I have done today. The first row doesn't change. The other rows do change.
Lynnea
Lynnea1941
Epson P700
I have done 15 sheets of print head alignment today, and I do see improvement. But, just no change with the first row. All the numbers are now crisp. I plan to do more sheets tomorrow.
Any idea about the problem with the first row? I am checking the squares with an magnifying glass, and I see no change at all.
Thanks,
Lynnea
thebestcpu
Printing Ninja
Epson SC P900
HI @Lynnea1941
I have an Epson P900, and the pattern they use is unfortunately not the same as what you show for the P700. A bit odd since the head and mechanism are the same. I don't know if that is because we have different firmware versions or if they are just different between the P700 and the P900. I show my head alignment pattern in the attached image.
I did find one reference online indicating that, for your particular pattern, the first line does not change, and that is normal. If you were in touch with Epson support, I don't know why that wouldn't already be known.
I would like to know if you have the latest firmware on your P700. If not, you could consider upgrading unless you have a reason not to.
Also, I would suggest that you do a nozzle check to make sure there is nothing funny going on with the nozzles, causing some issue with the alignment pattern (not likely, yet worth checking)
Then I would like to know if you are seeing any problems with your actual prints. If not, we may be overthinking this problem, and it might be time to just move on (or have a better Epson Tech, as this should be a simple issue for any good Epson Tech IMHO)
Just some quick thoughts
John Wheeler
Lynnea1941
Epson P700
Hi,
Thanks for your help.
I do have the latest firmware. I will check with Epson support re the first line. I will query them about it.
Thanks for that tip.
I did have a print problem before I started the print head alignment. I did a nozzle check. I did a cleaning. Both were good..
My plan is to do more alignment papers, and then try a print.
Thanks for your reply.
Lynnea
Lynnea1941
Epson P700
Could you please include a link to the reference in regard to the first line?
Also, is it the goal to have all the "best" square in a specific column. I notice that you have a large number in column five.
Thanks,
Lynnea
No, there is no verification print after you enter the correction values and finish/close the alignment job.
When you start the alignment job again it starts from the uncorrected status. It just may display your last entries. So don't go into an endless iterative cycle.
thebestcpu
Printing Ninja
Epson SC P900
Could you please include a link to the reference for the first line?
Also, is it the goal to have all the "best" squares in a specific column? I notice that you have a large number in column five.
Thanks,
Lynnea
Hi @Lynnea1941
Regarding the first line, I tracked it down, and unfortunately, the trail led back to your post here on PrinterKnowledge, so it's effectively incorrect.
As far as the goal, I agree with the post by @Ink stained Fingers.
I have found no information or references indicating that you should have a goal of a head alignment print with all the best boxes in a single column. Only pick the best boxes in each row, and you are done.
I took a look at the P700 service manual and did not see any better clarity there either.
Unless you are experiencing print quality issues, I would proceed with your printing projects.
John Wheeler
Lynnea1941
Epson P700
Thank you all for your help. I admit, that I was really at a point where I wanted to get rid of this printer. But, I continued with a couple more alignments, and today, I did the very last one, and that top line finally had a square that changed. I quickly cranked up Photoshop, did a conversion from sepia to black and white, did some adjustments, and printed the very old image. Wow, I could finally read the text for the scan of a cabinet card. I had done the scan in 2012 when I scanned over 800 family photos. The scan was high quality, but the cabinet card was really old. I had repaired it in Photoshop, but, there wasn't much I could do as it had been a family photo for at least 100 years and not stored properly.
The lesson learned for me is that patience is important when doing this work.
I'll have to see how prints look from digital images and not from scans.
Thanks, again. This forum was very helpful, and I think Epson support just gave up.
Lynnea
