Anyone using the PRO-310?
Paul Verizzo
Sarasota, FL, USA
Like photography in general, I'm manic depressive. Don't do anything for years, then jump into the deep end. I've not done "art" or large format printing for years. Now, I'm wanting back in.
I've used Canon printers for decades. All dye based. Last large format, PRO-10. I've avoided pigment inks for many reasons. You know most of them. Bronzing, Nozzle clogging. Not so great for non-matte papers. (That's one of the reasons matte joined the big leagues, despite lower gamut. There's a reason pre-inkjet glossies were the standard.)
I'm now considering the Canon PRO-310. It uses the second generation of Lucia pigment inks as used in the PRO 1100, which both Canon and users find better, especially gamut. It also has, I'll call it nozzle switching technology, a nozzle clogs, and it uses another. It also has the Chroma Optimizer clear coat. FYI, Canon had something like this decades ago. To me, the 310 makes pigment ink printing finally arrived.
I did look at the Epson ET-8550, a tank printer. It's an all in one, which I do not need. At about $100 less, it's tempting. But then I thought, if they can do all this cheaper, including the scanner function, what else is cheap or of lesser quality. Bzzzt...... I decided that I would pay more for the printer and inks than go with something logically inferior. I've afforded printing because I always refilled cartridges. Until someone comes out with a Lucia 2 ink formulation, I'll just bite the financial bullet. Or, maybe, a continuous feed?
Back to my question, anyone using this printer?
Among the regulars in this forum, I don't recall anybody who owns a Canon Pro300/310. Maybe there're, I wouldn't know for sure. Most people here refills the carts. Until the Pro 10/100 generation that was feasible because there're chip resetters. Not so with the newer Pro 200/300/310. It seems that it's almost impossible to decode these new chips or that the manufacturer of those resetters think it isn't worth the time and money involved in developing them. Therefore, with a Pro 200/300/310 either you purchase only OEM cartridges or you refill with third party ink and disable ink monitoring. That’s "living dangerously", because you won't know when a cartridge needs to be refilled and it's easy to imagine what might happen to a Canon printhead when you try to print with no ink.
Chroma Optimiser was introduced by Canon on the PRO-10. This removed most of the objections against pigment ink on glossy papers, PRO 300/310 did not add anything at this point.
As a long time PRO-10 user, I would seriously consider the Epson ET-8550 if I had to start over. PRO 300/310 no way.
@Paul Verizzo - you may have a look to this thread discussing the option to run pigment inks on the ET-8550.
https://www.printerknowledge.com/th...pigment-instead-of-dye-inks.16196/post-140304
There are practically no mechanical or electrical - with chips - limitations to use the inks of your choice which can be lower cost 3rd party inks like InkTec or even Canon genuine inks like the Lucia (II) inks or inks for the Canon large format printers by draining the cartridges
This guy (who bought the Südhaus dye ink license) also sells Inktec for Canon and Epson.
oliver666
Canon Pixma G6020
I have the PRO-310 and it's easily the most consistent pigment printer I've used. Nozzle switching works as advertised, and the Chroma Optimizer really helps with gloss papers. It finally feels like pigment printing without the usual headaches.
Nozzle switching on larger format printers (from PRO-1000 on) seems to be based on reserve nozzles.
I wonder how it is done on the PRO-310, since this printhead is not originally designed for.
PS: seems it is done in software:
>For efficiency, a nozzle recovery system works to help ensure that is a clog is detected in one nozzle, other will automatically compensate, contributing to the reduction in the frequency of head cleanings while working to prevent print waste due to banding.<
I would take this statement with lots of salt... If the printhead is the same of the Pro10/300 and a specific image requires all the available nozzles to be fired in order to print well that image, I don`t see any clever software doing the trick.. IMHO that's just Canon marketing bollocks to promote the sales of the new printers. In fact, the Pro-310 is less Pro than the Pro-100/Pro-10, which are mechanically built to a much better standards.
Most probably the claimed reduction in head cleanings (and ink consumption) is simply because they exagerated in previous models, and experienced the printhead introduced with the PRO-10 almost never clogs.
So it's easy to say "...while working to prevent print waste due to banding" . This never happens.
