Four flashing lights issue on Pro 100
Paul Verizzo
Sarasota, FL, USA
I've not used the printer for five years, decided to fire it up again. I installed a set of generic cartridges, and I get four flashing orange lights. Canon says in different ways, it's about ink cartridge readings, Nothing enlightening. https://support.usa.canon.com/kb/s/article/ART152997
All cartridges light up as normal.
Any insights?
The printer doesn’t recognise the 3rd party ink cartridges..
Quote ”Install the appropriate ink tank.”
Or.. Flood the purge unit with Windex and run a cleaning cycle, the wiper may be stuck..;)
Paul Verizzo
Sarasota, FL, USA
Not about to spend $116 on a set of Canon cartridges to test that theory. I've never had issues with knockoff cartridges in other printers.
As to the purge suggestion, I honestly have no idea what you mean.
I didn’t mention anything about buying OEM carts, that’s was a Canon recommendation, the purge unit is where the print head sits when not in use..
To clean this unit, let the printer start up as normal and then pull the power plug when the print carriage moves toward the centre, this will allow you to push the print carriage all they to the left side.
While using a flashlight and large syringe squirt lots of Windex onto and over the purge unit, don’t be afraid to drown the unit in liquid, leave to sit for a few minutes, then power back on the printer, this may clear your error message..
If the printer flashes in orange 4 times then it's a problem with the chip cartridge(s), not being recognized, either because there's no cart installed, or because the chip is defective or the contacts are oxidized. If the blinking was alternating orange/green lights then it would be purge unit error, but you said it was orange lights only ?
Best scenario for you is dirty/oxidized conctacts ,because you can fix that. Now and then I have this problem with my Canon Pro10 cartridges. I've been refilling those for 7 years and they're well past their prime days. I clean the contacts with a tiny dab of tissue soaked in alcohol. Sometimes, before the alcohol I rub them with a small fragment of sandpaper.
If cleaning the contacts won't fix the issue then you'd need new carts.
Open the cover of the printer and you'll see which carts are giving trouble,. maybe it's only one or maybe all of them.
I expect that in the maintenance tab of the driver you'll get this information too.
You might have to clean (gently) the contacts in the printhead too (with a cotton swab and alcohol).
Music Lover
Brother J1010dw
Sounds like the printhead might be clogged from sitting for so long. Even with new cartridges, the printer freaks out if it can't get ink through.
Your best bet is to find the "Deep Cleaning" option in your printer's software on the computer and run it a couple of times. If that doesn't clear it, the printhead is probably too far gone after five years. At that point, it's often easier to just replace the printer.
For starters, if you don’t know anything about this printer, then don’t give poor advice, many a good printer have been lost due to duff advice..
The Pro 100 is a very sturdy last lasting printer that can have issues from time to time but can usually be solve with good advice, for this printer 5 years is just a walk in the park.
Never recommend doing more than one Deep clean at a time, because mutable deep cleans can put a massive heat strain on the electronics of the head, causing permanent damage, and if that happens then a new print head is the only option..
