Printers with built in automatic 24/7 cleaning cycles?
Smile
Europe EU
What brand of printer desktop size or wide format has auto 24/7 cleaning cycles built in? That would prevent clogged printheads.
I know that all Brother piezo inkjet printers clean printheads every day. Uses low ink. My MFC-5895CW is 14Years old.
Share if you know anything related to the topic.
I think all inkjet printers do it, but few publish when and how much. It is an inevitable part of the technique (piezo or thermal).
Strange enough recently even our - most appreciated - expert Keith Cooper started to worry about the PRO 1000/1100 wasting too much ink.
Inflation ?
Inflation ?
I think it's inevitable - you need a particular amount of ink per nozzle for a cleaning action, and just look to the number of nozzles per printhead over time - the number of colors of the inks is growing and the width of the printhead as well - more nozzles give you a higher speed or a better resolution , and you get for most colors multiple nozzle rows by Canon etc , and just multiply all that for the total number of nozzles , you get many thousends of nozzles alltogether, that can easily get you into 5000 or more. And you need a drop of ink for any of these nozzles.
Smile
Europe EU
Doesn't Canon, EPSON require you to run cleaning cycles manually. Did they bought patent from Brother allowing them to run cleaning cycles automatically?
roncromberge
The Netherlands
🪦 P900 | 🚼 SC P5300
The most important thing is NEVER unplug your printer from the power-lead!
About the automatic headcheck feature, I know my old Canon IPF5100 had a automatic check and clean routine. From all the other printers i know off this feature is not mentioned in any manual! So beter place a reoccurring reminder in your agenda to do a head clean on the printer. (This is also what Keith Cooper do, and recommend!)
Not all printers are the same. Even within models of the same brand there're huge differences sometimes. I know for experience that Maxifys couldn't care less if you let them plugged to the mains or not. Mine is stored on a shelf most of the time, power cable disconnected. When I need to print, the machine is relocated next to the computer and I switch it on. Once powered, it performs an automated cleaning cycle only when "she thinks" it's necessary. That doesn't happens often, far less than with my Pro10s which I keep plugged to the mains all the time.
