Epson L5190 paper feed problem
The Dumb One
Epson L5130
Hi all.
Got a bit of a problem. Epson L5190 ink tank printer prints beautifully. The only issue I do have is this, whenever I print multiple sheets, whether from a pdf, a docx or a web page the printer will every now and then fail to pull in a page completely into the paper feeder and it would then show "paper jam" while sometimes it would pull in a page and then push it through as a blank page. This happens randomly during the print. All other pages not affected with this issue print out perfectly. It is frustrating, to say the least. The paper that registers as paper jam is wrinkle free with straight edges. The blank paper is completely clean with no print marks or smudges. The feed rollers are clean, and the texture of the rollers are course (the way they are supposed to be) Multiple tries printing multiple pages has yielded different results eg. print test 1 will give problems with 2 pages in a 15 page batch while the next print batch test will leave me with 4 pages with issues out of 15.
Also need to mention, I flashed with the latest firmware as well as installed the latest driver available.
Any help would be enormously appreciated.
You are right that this is a pretty annoying printer performance; please let me raise several questions -
- how old is the printer - possibly still under warranty
- how much are you printing - a lot or not that much
- can you feed paper from diffrerent bins - does that make a difference
- does it happen more frequently when the paper bin is full or rather empty
- did the problem developped just recently or exists already since a longer time
Do you have access to the pickup roller - it could help to use a rubber roller cleaner if the
pickup roller slowly dried out over time, there are rubber cleaners on the market typically used
on copy machines, these could be cleaning sheets like these - as an example, you can find similar items in your country
https://www.amazon.com/-/de/dp/B0DCVL8Q26?__mk_de_DE=ÅMÅŽÕÑ&crid=3KBIFMQZVK7YX&dib=eyJ2IjoiMSJ9.RcyNjwQkXM8Qc5ggxcQDBVmTkbXpJe2EeoFjNKqXOU1RhDf-7sdnIF7WDGBcm0ZmlP9kaNH5YkmOWmulOY3ylFQ_5a0Xd951xi5xAhwAikRGpV724AMRdoSfLhQMaFQgVnp6cCgwyQn1MfDmsORlcFOPt0K_RAbmjF4TEBNIscYeqwj-WtUUulWHc5ku9839StLu-CFO90jiGrr6nBtGsT43n28I2wJRXNTkWIZ_C2bLiWs_pKL4D5t3yqtCTN9IgYffJPujWGTgdQVKhBNxF_iwA537PK6U53zk6EgbGnE.wSXD3BR_XwPgHx9vbhjgTvlzt4AjczhZyJz2CCtW-Mg&dib_tag=se&keywords=rubber+roller+cleaner+sheets&qid=1753632395&sprefix=rubber+roller+cleaner+sheets,aps,176&sr=8-6
You may find as well some rubber cleaning fluid which you would wipe over the pickup roller or you spray it on a piece of paper - almost wet it - and feed it through the printer several times.
The Dumb One
Epson L5130
Hi there. Thank you for the quick response.
A quick background info piece. I am a self employed computer repair technician (Certified and registered in South Africa) The printer is situated in an office for the local welfare. Because my forte is field services and breakdowns, I do not spend a large amount of time on printer repairs specifically (Although I can help myself somewhat).
A quick rundown on your questions are as follows.
-The printer is approximately 3 years old
-Print load is normally less than 20 pages per week. (It is in our local welfare office used by the admin manageress. There is a networked Konica Minolta printer that is used for bulk office printing.)
-There is only the back feed chute for paper loading.
-I tried various paper loads, from 6 pages up to about 25. Both problems are intermittent with no discernable frequency.
-I am of the opinion that the problem MIGHT be present for a long time, but I can not state that as a fact.
-I had a visual inspection at the paper feed assembly and the feed rollers as stated, but all seemed and felt in good working condition. I did discover paper "dust" on the exit rollers and the chassis interior, which I cleaned. The reason why this issue is somewhat important is because the Admin manageress is in the process of creating and printing booklets to raise awareness of social issues in our local community as well as writing motivation for consideration pieces that gets submitted to potential donors.
I understasnd that such paper feed problems are pretty aggrevating, it may fix the problem by cleaning the pickup roller.
Does the printergive you some other options via the driver like low noise/night mode which slows down the paper actions, this might be available via the extended settings, as well the ext. settings on the service/maint tab.
Changing the priint quality to high slows down the paper movement as well. This might be worth a test.
I understand that such problems typically evolve over time, the environment - hot and dry - may accelerate such effects.
