New Epson EcoTank ET-8550 with Epson pigment inks
razer
I recently acquired an Ecotank 8550 and I am going to test out the viability of using Epson pigment inks.
I already purchased the Durabrite ET 542 pigment ink set, and I am harvesting Epson pigment inks for the other colors from cartridges.
Wish me luck.
  • Like
Reactions: x64
x64
Good luck, I'm interested in your results. As a note for your experiments, the various inks Epson produces differ 'somewhat' in composition. You can find the differences in their safety data sheets.
razer
Yes, based Epson's prolific usage of the print head found in the 8550, I am confident the 542 pigment inks will yield good results. I am not as confident about the photo black and gray pigment inks, as they seem to be only available as Ultrachrome inks.
razer
I have to say, I am absolutely loving the ink tank system. There is no way I can return to a cartridge based printing system.
The 8550 is filled with pigment ink and the initial nozzle check and print on copy paper was successful, nothing looks out of the ordinary. For the photo black and gray inks, I used Epson Ultrachrome ink harvested from cartridges.
I have some Epson photo paper on order and I acquired printer profiles from Keith Cooper. I will then proceed with further color testing.
The name Ultrachrome is just a family name for a wide range of pigment ink sets, and even dye inks over time, there are several generations of these inks on the market at the same time, new printers , mainly in the large format printer range , may add another new inkset, or a new color to an inkset. Durabrite inks are targeted more to the jobs of business - office printers , the requirements are different - faster drying to support duplex printing, less abrasion on non-coated- office type papers . Durabrite inks don't thrive for the widest gamut or the best gloss etc.
razer
Yes, very informative.
As soon as I receive the Epson paper I ordered, I will see how the different inks interact.
Lothman
.... For the photo black and gray inks, I used Epson Ultrachrome ink harvested from cartridges.
So which profiles did you buy? Using another inkset on the 8550 makes the profiles Keith Cooper did for original 114 inks most probably useless.
razer
Yes, I am going to use Keith's profiles as a starting point. There will be lots of test prints. Fortunately, I have a 17" roll of Epson photo paper from a previous job.
razer
After numerous attempts, I have settled on a workflow for creating profiles for my Epson ET-8550 using pigment inks. I installed the latest version of X-Rite's i1Profiler and dusted off my old i1iSis chart reader. I created and printed my target chart. After using my i1iSis to read the chart, I saved the results as a CGATS file. Seeing as my device does not have a license for creating profiles in i1Profiler, I had to rely on ArgyllCMS.
For my purposes, I limited myself to using the following components of Argyll.
txt2ti3.exe -v Epson_Photo_Semi_Gloss.txt Epson_Photo_Semi_Gloss
colprof.exe -v -qh -S sRGB.icm -cmt -dpp Epson_Photo_Semi_Gloss
profcheck -k -v2 Epson_Photo_Semi_Gloss.ti3 Epson_Photo_Semi_Gloss.icm
I am really happy with the results from my test prints. I will be ordering additional paper samples and continue with the process.
