Colormunki Photo device and ccStudio
Smile
Europe EU
Smile
Europe EU
@Smile - thanks for the links, the aliexpress links just tell me that the item is not available at my location; I'll try early next year to contact the 'Made in China' link,
There is a rarely known effect with the i1 spectro and this halogen lamp, when you reach the end of the lifetime of this lamp the calibration status of the spectro becomes dependant on the actual voltage of the 5 Volt line, this 5V line can vary between 4.8V to 5.3 V as I see on my hardware, I have an old spectro which calibrates on a USB hub with an external power supply providing 5.2V under load, and the same spectro fails calibration when connected to an USB port below 4.9 V . It's the lamp brigthness which varies strongly with the supply voltage - acctually every filament bulb does this. Looking for and using a higher voltage USB connection can give you a little bit more lifetime for an old i1 spectro.
Get a simple USB voltmeter like this one to test your USB ports
https://www.amazon.de/YEREADW-Strommessgerät-Multimeter-Strommesser-Spannungsprüfer/dp/B0DF2KFDC8?crid=P9PIKOIB421H&dib=eyJ2IjoiMSJ9.BPuwOtgiv2SZAHvHIFVVhUzzV3fmq0aUWVGGTbbIyi--mTp9l87OixHpOtNKStDR8kYy_e8eU2ljrC4rNc35g0kzgTtmJjo6baKXs7tyvzMlwRxzSygbmN85_AGiNgEpPBqUcxjBJsBmdCj1N4oX52_03RDo_jt-EqsMst7rnZsprX4BPj_fem1x45so4R5ZUw9uQRRZ8yXMlt4iyqmVTdAbIKB4gGJkU4Ww_NOSGDGN-SKvuXaFZMce09cxzvy8LlXSdFHDAvg6UpEvDUl4O-fGeUTDwmqeqJxi4cZcg8bVjx3riGwO8bRE78hF6B7DTjArsPH3hx0OxtRtSIqyweDeHd1UbCiP8fGmc7YEOLWnMeFdhlBuSeyRTxx0SDfsaFYhoacnS3bw7YIyPCzvrYzlc55eG4CoBYKp3Jlxpfmj_Npf7WH2YhUzIm7AHNgy.TkwJuPmPw4MMKJp-7nPJh0mTIFt4gBLpz9P1TP-Wzmc&dib_tag=se&keywords=usb+power+meter&nsdOptOutParam=true&qid=1735115591&sprefix=usb+meter,aps,138&sr=8-15&th=1
There are plenty of such meters available on various platforms - as well Ebay.
Smile
Europe EU
Did you manage to buy the lamp mentioned? I myself wonder it it works OK.
Your Aliexpress links don't seem to work anymore; I currently don't need a lamp for repair but just as a backup.
I'm currently trying the 'made-in-China' link
Latest posts
