How to remove PRO-1 printhead ?
Just wondering if it's worth spending the £40 on inks or is the printhead dead ?? Thank you.
The only way to be certain is to get a set of OEM carts and run a deep cleaning cycle, then a nozzle check, if you have no improvement in the various colours then the print head is most likely fried, whatever you do Don’t print any test sheets until you get a perfect nozzle print.. if the head is damaged then the only other choice is the dumpster.. (Heads are Unavailable and non-repairable..)
P.S. The reason for buying OEM inks are because they are the best at cleaning out any nozzle clogs..
kevinhughes1
canon pro 1 and 10s
Thanks man it's just two inks I need so I'll order today
kevinhughes1
canon pro 1 and 10s
OK, but don’t run a system clean..
Just fitted the two new cartridges and ran the deep cleaning and one nozzle check here's the results please say its OK 😂
kevinhughes1
canon pro 1 and 10s
Just noticed pink in the co
Scratch that ran another clean on the co and it's group and the pink has gone can't believe it's not been used for 2 possibly 3 years and still runs
