- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
I was too quick to say the Canon pigment ink doesn't smear. This is after a few minutes. Maybe this is caused by adding cyan and magenta dye ink to get a more perfect/neutral black. I'll do more testing to find out what's going on. B/W copying might be a solution.
Here is the smear test using five drops of "pharmacist's cleaning fluid" applied in the centre spot:
Edit: the printer does add colour dye ink to the print, see this 50 X magnification of dots from the lady's dress:
Making a B/W copy of the print using a Canon MP800 with plain paper setting results in a print with only pigment black, no dye ink added:
This might also work with your printer. You could try printing the image on cheap plain paper and then make a B/W copy on the expensive watercolour paper. Maybe the smooth watercolour paper will not smear when dye ink is not present?
