Hi, I have a pro9500 Mark2, because of the B200 error message, I want to reset EEPROM,
jbhtjbht
pro-1 pro9500mark2pro9000mark2
大家好, 我有一个 pro9500 Mark2, 因为 B200 错误消息, 我想重置 Eeprom, 问方法, 谢谢
Translation
Hello everyone, I have a pro9500 Mark2, because of the B200 error message, I want to reset Eeprom, ask how, thank you
Edit:
B200 means the printhead has failed. A reset will not repair the printhead. You need a new print head which I think is nowhere to be found.
A google translation to Chinese:
B200表示打印头出现故障。 重置不会修复打印头。 您需要一个新的打印头,我认为找不到它了。
jbhtjbht
thank you!
Tony4597
Cheshire, UK
Epson Surecolor SC P800
Translation
Edit:
You may be able to source either a new print head or a refurbished one from Shen Zhen, China. Have a search on eBay and you may be lucky
您也许可以从中国深圳采购新的打印头或翻新的打印头。 在eBay上进行搜索,您可能很幸运
Refurbished print heads out of China are not very reliable and therefore should not be recommended here, you got a better chance playing the Lotto..
Tony4597
Cheshire, UK
Not a recommendation just a comment. Buyers need to exercise due diligence in the purchase of any product from any country, including the UK!
I can only speak of my own experience with HP printhead replacement from China and Cationic UV printer spares again refurbished which I found to be perfectly acceptable.
Interestingly a new print head again from Shenzhen (maybe the original manufacturer for all we know) can be purchased for between £50-£60
Obviously, your own experience sounds to be based on a poor outcome?
Do you have a link?
Tony4597
Cheshire, UK
Do you have a link?
Seems I was looking at the 8500, 9950 and Pro9000 @£54.00. Not sure if this link will show as the last one edited and removed
https://www.ebay.co.uk/itm/Printer-Printhead-Printer-Head-Replacement-for-Canon-IP8500-I9950-Pro9000/173890216192?_trkparms=aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=20201210111314&meid=9fdabfc2a89f46088fa521bd0df32ecd&pid=101195&rk=1&rkt=12&mehot=co&sd=402662906255&itm=173890216192&pmt=1&noa=0&pg=2047675&algv=SimplAMLv5PairwiseWebWithDarwoV3BBEV2b&brand=Unbranded&_trksid=p2047675.c101195.m1851
Anyway, Canon has had long links with China for the manufacture of printers etc. Starting I think in Taiwan in the 1970's and up to 2010 printers manufactured in Thailand and Vietnam. After that time I believe China with Canon Finetech Nisca (Shenzhen) for business machines, printers, and peripherals along with Taiwan. I suspect that the parts are all manufactured in China even if assembly and distribution elsewhere
If the required parts not available in other countries China would seem to be a logical place to look. Assuming that the printer is worth restoring age and general condition etc.
Thanks for the link @Tony4597 .
I wonder why they do not ship to the USA?
Screenshot_2021-02-02 Printer Printhead Printer Head Replacement for Canon IP8500, I9950, Pro9...png
Ludo
The Netherlands
canon ix5000
Hello jbhtjbht
Every printhead of canon printheads have a eeprom on the back side of the green pcb with the golden contacts. That eeprom got corrupt and you have a B200 error.
reprogramming that eeprom solves the problem.
What you need is the original hexdump of that eeprom.
You can print it out with a ""service tool"" for canon loaded in your PC .
Also set your printer in sevice mode . How to do that for your printer use Google .
This only works on printers who are without any errors.
So I advice everyone to print out the hexdump when your printer is in good condission . Whenever your eeprom got corrupt you can always reprogram that eeprom by a electronic engineer. It is cheaper dan bying a new printhead.
Not only the printhead has a eeprom also the mainboard in de printer has one.
The printout gives also this information.
as I said service tool does not work with a defect printer so you have to buy a new
printhead to solve the B200 problem.
advice :make a printout when printer is without errors and store the printout of the hexdump for later use. You will never know you need it in the future.
