Really-Peter
- Jul 28, 2019
- North Yorkshire
- Canon iX4000, Canon iP8750
I didn’t know that I had a problem with the print quality on my printer, until I used it to print four colour swatches to be sent to a paper supplier for them to create ICC profiles for use with their papers.
However the company concerned emailed me to advise me that the swatches I’d supplied were not good enough to create any ICC profiles from. They did offer suggestions regarding ways to overcome the banding that they identified. To be honest I didn’t notice the banding!
I have always used Canon ink cartridges with the printer. The printer is only used occasionally.
I have run a couple of Nozzle Checks, print head alignment, a clean and a deep clean.
Looking at the last nozzle check print (attached) I’m unsure if the lighter lower part of the second magenta strip is correct or if this is a problem?
I would appreciate some of your knowledge in determining if there is still an underlying problem with my iX4000. I did run a nozzle check on my iP8850 printer to compare it against the iX4000 one (I may be trying to compare apples and oranges).
The only difference that I could see was in the horizontal colour blocks at the left side of the nozzle print. Those on the iX4000 have a solid pair at C & M with corresponding half twin colours. I hope that makes sense.
I look forward to your thoughts/comments regarding the nozzle check print.
My apologies if I haven’t supplied sufficient information.
