B
Beadsmistress
reacted to
AmaDeuSbg's post
in the thread
Epson ET2800 head cleaning question
with
Like
P.S: The cartridges should not be full full, there should be half of the cartridge full of air (about 50% full is OK), left should be...
Oct 18, 2025
B
Beadsmistress
replied to the thread
Thank you, I appreciate this new info. I did pull a good bit of ink in, but they’ve settled and I just checked. They’re all about half...
Oct 17, 2025
A
AmaDeuSbg
Oct 17, 2025
A
AmaDeuSbg
No problem, hope the printer is revived in the end. Even if cleaning solution is left in the nozzles it is no problem, the ink will push...
Oct 17, 2025
B
Beadsmistress
Hi, thank you for your reply. I didn’t know what a damper was, (lol, I’m an adventurous old lady) but it was easy to find out. And, yes...
Oct 17, 2025
A
AmaDeuSbg
Hey, Most likely due to the inactivity the ink in the dampers went back to the reservoirs and the ink lines and dampers are full of...
Oct 17, 2025
B
Beadsmistress
posted the thread
in
Epson InkJet Printers
I converted one of my Epson Et2800 printers for sublimation. It was brand new, I use Hiipoo sublimation ink and all was well until I...
Oct 17, 2025
B
Beadsmistress
posted the thread
Hi, new member here!
in
Member Introductions
I’m a crafter with 3 printers. A Canon TS9521c for color printing, an Epson ET 2800 for everyday printing and another Epson ET2800 for…...
Oct 17, 2025
T
thebestcpu
Epson SC 800 & p900 which one to buy
Your welcome @drfihl John Wheeler
Oct 17, 2025
D
drfihl
Thanks Thanks John. Helped a lot. P900 is ordered plus an extra LGY. ChatGPT says 15-20 ml ink will be used at startup. Gives me time...
Oct 17, 2025
D
drfihl
reacted to
thebestcpu's post
in the thread
with
Like
Hi @Carsten I have the P900 and my brother has the p800. I have done quite a bit of technical testing of the P900 and have shared...
Oct 17, 2025
A
Printing won't print solid black on documents with mixed text and color graphics
I'm quoting you : “The black text comes out looking like dark magenta. However, when I print a straight text page in black, the black...
Oct 17, 2025
S
Soso
reacted to
Vogelkop's post
in the thread
Best wide format Epson for refilling?
with
Like
Hello everybody I have two Epson Pro 7900's that I am about to give up. The story of me trying to rescue them are long and sad, so I...
Oct 17, 2025
T
thebestcpu
Oct 16, 2025
T
thebestcpu
Just to let you know, you did not scan and share the nozzle check pattern. It helps to visually see the pattern (not your text...
Oct 16, 2025
