E
Epatcola
replied to the thread
ET8500 Borderless
You don't mention so it sounds like you missed the driver preferences having a settings button next to the borderless checkbox which...
Jul 29, 2025
PK Project Manager
@turbguy, look at you go! Your photo’s this week’s standout, and it’s now holding it down on the homepage! 🎉📷
Jul 29, 2025
PK Project Manager
reacted to
turbguy's post
in the thread
with
Love
A summer sunset from Laramie. Did you know the name was French, named after Jacques La Ramée? He has the city, a county, a river, a...
Jul 29, 2025
Epson L5190 paper feed problem
I understasnd that such paper feed problems are pretty aggrevating, it may fix the problem by cleaning the pickup roller. Does the...
Jul 29, 2025
Canon Megatank : Resetting waste counter - Help needed (G5000 - G7000 series)
- Which of the G-series megatank printers does not come with a user replaceable waste ink box/maintenance box, counters get a reset with...
Jul 29, 2025
J
James Mike
Is there any chance that the old method(button press) for resetting was added back in a firmware update ? saw a recent video of a G6070...
Jul 29, 2025
J
jaziek
reacted to
mavtop's post
in the thread
Epson XP-15000 OEM and refillable one time cartridge and waste ink resetter
with
Like
Talking about borderless printing: in my epson xp 15000 if i use borderless print, i can only choose expansion min, med or max, but...
Jul 29, 2025
J
jaziek
posted the thread
ET8500 Borderless
in
Epson InkJet Printers
Hi! I'm trying to print a PDF that goes almost all the way to the edge of my paper (less 0.3mm) however, if I try to print it regularly...
Jul 29, 2025
Pixman
How did I brake my Pixma TS8350 by lubricating it?
Sorry for this noob question, but how do I get to those parts so I can give them a proper cleaning? I still can't reach those sensors in...
Jul 28, 2025
Pixman
I took a few more shots to show you where the grease/lubricant ended up. You can see the splatter on this big circular housing or...
Jul 28, 2025
Pixman
I took apart most of the covers of the printer and the scanner unit. This is what the motors, sensors and those gears look like. So it...
Jul 28, 2025
Empterdose
WTB: HP Photosmart D5160 CD/DVD media tray (UK)
The ET-8550 can print to optical media, yes, as can its little brother, the ET-8500. There are lots of positive reviews of the...
Jul 28, 2025
P
papadapadoo
reacted to
PeterBJ's post
in the thread
Cartridge for ML2165W
with
Like
I think "Samsung (now under HP)" is the reason your after-market cartridges no longer works. HP uses firmware updates to block the use...
Jul 28, 2025
Pixman
How does a printer know there is a paper jam? Do they have sensors for that? Are they located at the back, near the motor? I'm assuming...
Jul 28, 2025
x64
I usually use either PTFE lube on sliding parts and synthetic grease on gears. What kind of crazy product did you use, adhesive grease...
Jul 28, 2025
