Using purging to keep printhead from drying up
jjohnl
There's been a ton of discussions about how to keep the printhead from drying up; the most common suggestion seems to be to make a print every x number of days. But I had a thought (as I'm unplugging my Pro9000II for some weeks/months): Doesn't the printer purge every time you power cycle? Wouldn't that be enough to keep the printhead "wet" if you did that every week or so?
Emulator
Canon Pro9000 II
You are probably correct, as you say each time the printer is switched on you can hear the ink going down the drain :).
I do the same with my 9000II, with a nozzle check printout every so often, just to check that nothing is deteriorating.
Keeping the head parking station and rubber seals clean is also important.
