- Feb 24, 2005
- Location
- North of Boston, USA
- Canon i9900 (plus 5 spares)
This post will be of interest only to those interested in the technical details of measuring ink viscosity - don't say that you weren't warned.
There are often references to the ink's "viscosity" being off, and causing printing problems. Viscosity is the resistance of a fluid to flow - a fluid with a high viscosity does not want to flow as easily as a fluid with a low viscosity. To give a few reference points, these two links give the viscosity of water as 0.89 centipoise (http://dwb.unl.edu/Chemistry/MicroScale/MScale05.html) and 1 centistoke (http://www.sizes.com/units/centistokes.htm). This is interesting, since water has a density of 1.000 (grams/CC), and the centipoise and centistokes values should be the same for a fluid with a density of 1. For the purposes of this discussion, let's just use a value of 1 centipoise/centistoke for the viscosity of water.
For years, the "Zahn Cup" viscometer (viscosity meter) has been used to measure the viscosity of low viscosity fluids (http://www.geneq.com/catalog/en/zahn_cup.html). The appeal of this device is its simplicity. It consists of a cup with a calibrated hole in the bottom - you just dip it in the fluid that you want to measure and time how long it takes for the cup to empty.
This link gives the ideal viscosity range for inkjet inks to be in the range of 2 to 8 centipoise, so we need a simple device that will measure fluids with viscosities slightly higher than water to measure the viscosity of inkjet inks. (http://www.imaging.org/resources/leinkjet/part4.cfm).
I tried using one of my 30 CC syringes with a 1.5" long needle as a "nifty-cup", and it worked almost perfectly. I poured about 10 CCs of water into the top of the syringe, waited for the water level to drop to 7 CCs, then timed how long it took for the water level to drop to 2 CCs. In my case, this took about 15 seconds. I then repeated the test with various colors of my bulk inks, and the times were all very close to 35 seconds. Therefore, my ink viscosities are all close to 2.3 centipoise (35/15 x 1.0 - my nifty-cup took 2.3 times longer to empty when using ink than it did with water, so the ink viscosity is 2.3 times the viscosity of water).
It is much safer to measure your ink's viscosity than to blindly add water or glycerin to an ink that may already be within spec. There are a number of other properties (e.g. surface tension) that can also affect the ink's performance, and you may actually make your printing problem worse.
Notes:
1. Don't worry if your nifty-cup or procedure is different than mine since we are using a ratio of the times for water and ink. If your rig takes longer than 30 seconds to empty with water, you might want to use a shorter needle or a larger bore needle just to keep the test times reasonable.
2. You might find a situation where the water/ink doesn't flow due to an air-lock - just flick the needle with your finger to start the flow.
3. The ink will form much smaller drops than the water - don't worry about this. The small drop size indicates that the ink has a lower surface tension than water. (http://hyperphysics.phy-astr.gsu.edu/hbase/surten.html)
Notes:
