ThrillaMozilla
- Jan 18, 2011
There's no way to reset the cartridges on my HP C309a, so the printer cannot monitor ink after refilling. Fortunately, there are now some very inexpensive, precision balances (aka "scales") on the market, which make it it easy to check ink levels periodically by weighing the cartridges.
It takes only a few seconds to weigh a cartridge, record the weight, and get it back into the printer. You need to work quickly, since you want to finish before the print head parks itself, but I didn't have any trouble in accomplishing the task. Be careful not to let it park with a cartridge half out, because it could jam the print head. You probably won't want to pull the plug to keep the printhead accessible, since this will probably cause a purge cycle.
I wondered whether the printer would exact a penalty by forcing a purge cycle after weighing the cartridges. I did a test in which I opened the printer, weighed the cartridges, and then closed the printer, allowing it to do whatever it was going to do, then repeated the weighings. The printer did go through a brief cycle of its usual clunks and other noises, but maybe less than it would do to print the first page. The maximum loss in any cartridge was 0.01 g; the mean of 6 pairs of weighings was 0.0017 g loss. This is within the error of measurement. In other words, ink consumption by purging was undetectable.
The bad news is that you need to know the weights for empty and full cartridges, and you need to keep records. The best time to start is with new OEM cartridges. The information is also most useful if you combine it with a log of page counts vs. weights.
As for equipment, there are now some extraordinarily cheap balances (aka "scales") on the market for under $20. Be sure to buy a 100-g calibration weight if it's not included. It was also dirt-cheap. I just bought a balance with 100 g capacity and 0.01 g precision from Amazon. It's a fantastic device, with unbelievable performance for the price. I checked it against a Mettler. The calibration weight weighed 100.0024 g. The balance was accurate usually to +/- 0.01 g over the whole scale, or +/- 0.02 g at worst.
