[IP7250][QY6-0082] Blank pages / replacing printer head
mnmc
Canon IP7250
Hello, all!
I've replaced my print head but it turns out that new head was faulty (it wasn't actually brand new head but from other printer which I bought just for this printhead).
So, order of events was following:
  • I had fully working printer except that BK was blurry
  • I bought faulty printer (not powering on) to get head from it
  • I put that head into printer and error B200 appeared
  • I powered off the printer and put back old head
  • Unfortunately printer doesn't reacted to power button at all
  • After ~15 minutes I put power cord back and printer powered on
  • Now i doesn't show any error but just prints empty pages
Now, my assumption is that that faulty head caused some short circuit and break something on main printers PCB (hopefully not CPU).
Maybe VCC was shorted that why power supply wasn't able to start immediately after replacement?
Question is: what can cause to printer's head behave like that? I mean no error but also doesn't work properly. It probably should be something common for all colors/inks.
Head in question is QY6-0082. I've attached some pictures of both sides of head's pcb so maybe this help for someone who could deduce where to look for LV,HV and when to check if these voltages are coming. Should these be present all the time or only during actually printing something?
Thank you for any hints.
You now have no alternative but to get a new printer, if you purchase a brand new head, not alone will it not work because the main board has been fused out from the damaged replacement print head you put in, this new head will also suffer the same faith and get damaged from the damaged main board.
So unless your prepared to buy a main board and a new head together then the printer has had it, it’s time to move on and take on board what you’ve just learned..
mnmc
Canon IP7250
Yep, that's true. This is the reason why head which previously worked (not perfectly but still) now doesn't work - because main board is broken.
This advice convinced me 😁 Not heartwarming but true.
Thanks!
