I'm having a big issue with with my fairly new R2880 printer with occasionally poor nozzle pattern skips.
I'm using 3rd party refillable cartridges from Precision Colors with IS ink, and Cone carts with Cone ink and have the same problem even though both carts are different designs.
I vacuum refill all carts.
The problem.....
1. Print nozzle pattern on startup, nozzle pattern 100% good, perform printing session, do a final nozzle pattern 100% good, turn off printer with power off button to park heads properly.
2. Don't use the printer for 7 days, 100% good nozzle check on startup, printing session ok, 100% good nozzle check on shutdown.
4. Use printer 4 days later, one color 100% gone at starup nozzle check, run cleaning cycle, that one color doesn't appear, and another color disappears 100%, 5 cleaning cycles later no improvements. Clean the printhead with windex and rolled up paper
towel, clean capping area sponges, more cleaning cycles back to 100% good nozzle pattern.
5. Will print ok for a few days in a row, let it sit 7 days ok, 7 more days ok, 2 days later another color 100% missing at startup, goes through the same routine above to resolve it and it does.
6. Yesterday, I ran the 100% good nozzle pattern at startup, just removed the VM cart to see how much ink was in it, 80% full, replaced with same cart, run a nozzle check VM 100% gone! Many cleaning cycles later just a few sgements show up.
Put in all used OEM carts, 1 cleaning cycle later, 100% good nozzle pattern.
This sounds like an air in cart/print head issue, but very annoying to try and resolve it, especially when you just remove a cart and replace it to find the ink won't flow (which it did one second prior) and not much to fix the issue.
I really like this printer and the 3rd party inks, but ready to dump it as all I do is run cleaning cycles. In less than 3 months of ownership, I have used up over $300 - 400 of 3rd party and OEM ink, and consumed over 50% of my ink waste pad with only about 100, 8x10 prints!
Any suggestions?
Thanks,
Bob P.
The problem.....
Any suggestions?
Thanks,
Bob P.
