Epson L3160 Scanner error 100016 prevents printing, scanning or copying
colink
Epson L3160, Brother DCP 7020L
This is not my printer.
To the best of my knowledge printing, scanning or copying was working until user left it too long without use and print heads needed cleaning.
I carefully cleaned print heads manually as described in a YouTube video.
After refitting the printer head and the white boxes that move ink to the printer head, I attempted to use Maintenace/head Cleaning. Following the instructions on screen when I get to last key press (bottom right diamond button) does nothing other than the screen showing to press diamond button again.
After a few seconds the screen changes to “Scanner error 100016 - see documentation“ — see video here on Google Photos https://photos.app.goo.gl/GcCCDsRYyKigkETu5
The same error occurs with every function including printing, scanning or copying.
No surprise there is nothing in the printer manual about error 100016.
Any suggestions?
If I don’t get any suggestions I might do a printer reset and trust setting Up for mac is straightforward. I wil not have access to printer and will need owner to reset.
thanks ColinK
colink
I will answer my own question.
This video covers several causes of 100016 error.
when I got back to the printer I found a loose ribbon cable (base to scanner, one of three cables)
Only needed to remove two screws.
colinK
