Epson ET-8550 paper options
Rick Masters
Epson r2880
I am considering buying an Epson ET-8550. I have used Epson's upper end "fine art" printers for years but the cost of ink is ridiculous. From watching Youtube videos very similar print quality can be had with the much more affordable Ecotank printer. My only question is can the better Epson paper like the Cold press paper be used in this printer? Epson tech support says no but I have seen videos of printing experts using the thicker art papers with no problems. I suspect Epson is saying this because they want customers to buy the more costly printers. Does anyone have experience using these higher quality papers in their ET-8550? Thanks for any help in advance.
thebestcpu
Epson SC P900
Hi Rick
It is not an issue of thickness as the ET-8550 supports up to 1.3mm or 51 mil paper.
The main difference, I believe, is that the ET-8550 uses a mixture of dye and pigment ink, which will produce different results on the same paper as a complete pigment set of inks. e.g., different gamuts, black point, etc
There are pros and cons with dye vs pigment inks, so that might be a consideration for you.
I, too, have seen many use the ET-8550 with various papers. I think the key is that whatever paper you get, you will need a couple of essential items
1) An ICC profile for the paper/ink/printer combination, whether from the paper manufacturer or a custom-built one
2) The correct paper type settings in the printer driver, which controls the amount of ink dropped/drying time, etc. That information should come with the paper you purchase for use with the ET-8550.
I work with supported papers with ICC profiles and paper settings instead of going it alone, yet I am sure many will make their own profiles and test to see which paper printer driver settings are best to use.
Other paper manufacturers support a variety of papers for the ET-8550, including Red River.
These are just my quick options, and note I do not have the ET-8550 for printing.
I hope this info was helpful
John Wheeler
Epatcola
various
I have yet to see anyone demonstrate there are more than 3 1/2 actual photo paper settings.
Matt for any of the matt papers.
VFA for any of the matt papers printing slowly and using pigment black in the darker areas.
Glossy for any of the glossy and semi-glossy papers.
The 1/2 is for ultra glossy which provides a Best quality option that prints slowly and produces a different profile.
For the OP if you search hard enough you can find Epson provide profiles for these papers
Signature_Worthy_Exhibition_Fiber_Paper_for_ET-8550
Signature_Worthy_Hot_Press_Bright_for_ET-8550
Signature_Worthy_Hot_Press_Natural_for_ET-8550
Signature_Worthy_Metallic_Photo_Paper_Glossy_for_ET-8550
Signature_Worthy_Metallic_Photo_Paper_Luster_for_ET-8550
Several other paper supplies have profiles for the ET-8550 so if they managed to profile it the paper at least somewhat works on the ET-8550.
The other problem is feed rollers leaving indentations on some papers with softer surfaces.
Rick Masters
Epson r2880
Hi Rick
John Wheeler
Thanks for the reply and information. The guy I was watching used the profile for Velvet fine art paper with his cold press paper. This is actually what I've done for years with my Epson R2880 and that profile gave me good results. I will check out the Red River paper.
doane2u
HP OfficeJet Pro K8600 wide
So, is it possible to print on mixed media art paper, like the Canson Xl or Strathmore 400, etc.? or are they too absorbent? And what if they were sprayed with an art fixative first? Any one tried this or is it something I will just have to experiment with on the ET-8550 maybe on the VFA setting?
