- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
I have mentioned before just how sneaky Canon are getting with their print driver upgrades on their new printers.
I always taught that if I don’t upgrade the firmware myself then it can’t be done, well in a way it can’t but Canon sure have found a way to circumvent that little problem with the use of their print drivers.
It’s hard to explain just exactly what they do and how they do it but any new printer driver that you install has the ability of searching/scanning out any or every Canon printer on your system and making/altering them in little ways.
As to why this is done I have no idea but some of my printers have had slight changes done to them over the years, and I’ve never used or had any upgrades, I have always avoided them.
I have changed the drivers over to 64 bit some five or six years ago when I upgraded my computer system but got all of the print drivers from Microsoft and not from the official Canon website. (Correct Colour Adjustment back then)
Some of the changes are small like, minimum/maximum paper sizes, left/right print margins, print from last page, plus Duplex and Collate issues and Print Borders on certain papers, but the biggest bother to me now are the colour changes.
I don’t use colour profiles as most of you know but I do calibrate each similar printer to print the same using exactly the same inks with Colour Adjustment but this has gotten a little harder since my computer upgrade.
I lost all of these print setting when I reloaded the O/S but this time it is much harder to get the printers to sing from the same hymn sheet as they did before, from what I can see there are no changes in my system, except ! !
I have added a couple more printers to my stockpile since, so have they now got any influence over the other drivers ? Something similar happen when I added two printers to my print arsenal about 6 years ago and my minimum print margins went out the window.
I now get exactly the same results when using another computer with different drivers so the driver is not the cause, the changes are saved in the EPROM chip which have been altered from another source.
I reckon that adding a new print driver to your system has the ability to affect all your existing printers that you have already, who needs a firmware upgrade when you got print drivers with these capabilities, the average print driver size now is about 130 Megabyte.
Getting a brand new shiny toy to play with may cause more problems than you think !
