Canon MG3620
tech2700
Ottawa, Canada
Canon, HP
the trouble light flashes 8 times, I sourced it and could be ink absorber full. does any one know how to reset this error.
Thank you,
Artefil
F-37130 Langeais
MX495, MG7550, MG5650, MB2050
The easyfix link also has a service manual but in Chinese. From this manual it can be seen that the parts number for the ink absorbers is QY5-0368-000 if you want to search for a set.
tech2700
Ottawa, Canada
Canon, HP
8 times flashing is described here : https://support.usa.canon.com/kb/s/article/ART176497
You're right it means the absorber is almost full.
It's a maintenance warning. You must :
1- dismantle the printer in order to replace or renew your waste ink pad
2- Use the appropriate Service Tool to reset to O the D parameter which can vary from 000 to 100
here's a link for complete explanation : https://easyfixs.blogspot.com/2021/03/how-to-reset-canon-mg3600-series-ink.html
wow, thank you very much, it worked, did not thing there was any hope in it. I even called Canon and they said there is no tool available. printer was going to be garage.
tech2700
Ottawa, Canada
Canon, HP
yes I see that, thank you for helping out, appreciated
