G2260 Inkpad Issue
Paul Verizzo
Sarasota, FL, USA
Canon ip4500, 9000 MK II, PRO-
I bought this unit three or so years ago. After only using 25% of the inks, it stopped working, saying the waste ink pad was full!
So I bought a new one on Amazon for $10. No improvement.
Any ideas?
I replaced it with a G6020 all in one. No problems yet with 50% of the inks used. Probably no problems because I paid for the extended warranty! Unlike the G2260, it also has auto duplexing and a rear feed which is great for my photo papers.
Hi Paul... Very much my area of expertise. That said, the G2260 is shown as being compatible with the MC-G02 maintenance box so it should just be a case of replacing that cartridge and the waste pad counter stops being a problem.
https://support.usa.canon.com/kb/s/article/ART178790
If I've misunderstood and you meant you'd purchased a new maintenance cart when you said "So I bought a new one on Amazon for $10. No improvement." then I'd recommend purchasing an OEM unit from here:
https://www.usa.canon.com/shop/p/mc-g02-maintenance-cartridge?color=Black&type=New
For the G6020, that doesn't have a replaceable maintenance cart but I do have a product with video docs that helps when you hit the waste ink error on that. You can find the latter here with the kit linked from the video descriptions:
https://youtube.com/playlist?list=PLfYhJgWvstUK3B6DX_q-ZCQniSKpA6TIE
Trust that helps a bit with your problem.
