[UPDATED] G2010 Colour Print Head once again dies after 1.5 years
rounakr94
Canon Pixma E510, Pixma G2010
Last March I changed my G2010 Colour ink head as it decided to burn out it's magenta and yellow heads one fine day ( https://www.printerknowledge.com/threads/g2010-is-this-print-head-a-goner.16412/ )
Fast forward one and a half year and yesterday the printer again decided to but out the magenta and cyan head. Is this some sort of printer issue or just low quality canon spare parts? I have been extra careful this time as to not run the printer dry without ink in the tubes and also regularly printed random things to keep the heads running. I did a Deep Clean and even removed the cartridge and blew air into it to make the ink come out, a bit came out but that's it. No improvement on prints. Not even 1000 pages and the head is gone.
What it should print vs what it prints
I am using the printer in grayscale mode until Amazon delivers the new printhead.
Artur5
Kmt. 0.
I hope that you purchased it from a genuine dealer who gets that printhead directly from Canon.
It seems that lifespan of Canon printheads hasn't improved lately, rather on the contrary...
rounakr94
Yes, the previous one was an OEM packed unit (without the outer cardboard box) which I bought from Canon Service Center.
The one I bought now is a retail unit directly sold and shipped by Amazon.
rounakr94
Update: Managed to save the colour head by cleaning with a syringe, a lot of flushing with very slightly warm distilled water and a partial ink flush.
The colours are back to normal suggesting that the head was clogged and not burnt and are looking fine to me now.
Artur5
Kmt. 0.
Are you using original Canon inks or third party ?
rounakr94
All original inks. Third party here costs nearly the same as original so no point in taking the risk.
rounakr94
Okay, so another query.
Can I keep using this print head if it works?
I had flushed out all the possible water residue after cleaning by using air in syringe and only foamy ink came out at that time.
Will there be any side-effects of manual flushing like leaking from the ink input ports or print heads from using the syringe method?
nobb
Interesting, so maybe these Canon thermal heads are more robust than people make them out to be. If the head was suspected to be bad anyways, I would've had no problems just using something more potent like a mixture of rubbing alcohol and Windex to forcefully purge it. If that doesn't unclog it, then I would consider it dead.
When storing printheads long term after a cleaning, I personally flush some glycol (eg. car antifreeze) through after any cleaning just to get the water out first, before purging with air.
I guess only time will tell if this holds up long term, but if it's working I see no reason why not keep it in service. Weekly printing of a nozzle check has been the key in keeping inkjets clog free.
