HP PSC 1610 All in One
Emulator
Canon Pro9000 II
For a change I have a printer problem. This printer is the utility vehicle of the house. It has a black pigment and a tri-colour dye cartridge. I have been refilling with Websnails inks quite happily until now.
Suddenly the printer is scattering black ink everywhere but on the paper, bit of a mess, like some of the other recent posts.
I have flushed out the black cart and refilled, checked the sealing or otherwise of holes and vents, but it is still misbehaving.
It makes me wonder if I have suddenly reached some software limit where HP is telling me "that's as far as you go mate".
Does anyone know the answer?
Maybe you have hit the nail on the head, your cartridge has expired end of life..:(
Emulator
Canon Pro9000 II
I have two black cartridges on the go alternately and they have both started to have problems at the same time.
CakeHole
United Kingdom
Canon MP610
It sounds like the print head on the cart has reached the end of its useful life. Carts with built in printhead typically last around 7 refills give or take 2 or 3 either way.
Emulator
Canon Pro9000 II
Cynics might say about the same life as the independent print head!
Have you tested that the cartridge is not leaking? A leaking cartridge cannot print. Instead it will drip ink on the paper and other places inside the printer. You can test that a refilled cartridge is not leaking by placing it in a shallow tray for at least 10 minutes, with the nozzles facing down but not touching the bottom of the tray. The cartridge must not leak.
Łukasz
Poland
MG6250 (MG5150 before)
Hi,
What about purge/capping unit condition?
If Canon printheads suffer from faulty operation of purge unit, why HP won't?
Ł.
CakeHole
United Kingdom
Canon MP610
Purge unit is i doubt would have anything to do with his issue. His issue is ink flow related in some manner. Even with a half knackered purge unit things should work for a page or so when he switches carts and it does not sound like it does. I still say as its carts with built in printhead the have reached the end of their useful life, opening them up and cleaning them and the sponge out may help but i would not guarantee it.
Emulator
Canon Pro9000 II
Squeezy bottle with blunt needle.
What mesh? You may have hit on the answer?
