Thoughts on OrcaSlicer for 3D Printing?
Frankly guys, I don't understand why anybody would use CURA in the first place. A nasty unfriendly interface that seems to be shouting at the user 'go away you fool !
I have used CURA 15 04.6 from the very start, but then switched over to some Slicers due to others saying that this one or that one was better..
But in the end I went back to the old CURA reliable and have done all of my best work with it, and as I said if it Ain’t broke why change it..
If the printer doesn’t object, who am I to complain..
So 8 years on and it’s still my go to Slicer..
Brother MFC-L8690-CDW
I bought S3D slicer as it was the de facto slicer for printing 3Dlabprint RC models. It was a good slicer in its day and I still use for their models, however, it is way behind now in terms of features .
I tried Cura, didn't like the interface much, tried Prusa which is better but I have settled on Orca as it is the inteface I find most intuitive and I like the implementation of support painting, the ability to measure parts on the slicer, litlle things like that are useful, not essential, but useful at times
I also like the way they have implemented adding different parameters at chosen layer heights (Height range modifier). Most of the newer slicers can do that but I find Orca easiest to use.
If you watch this short video it explains why you might want to do that.
When it comes down to it any of the modern slicers will work just fine, just use whatever one feels the best fit for your way of working.
@Nifty - Give Orca a try and see how it goes, you may be surprised.
Administrator
Bay Area CA
CR-10, i560 ,MFC-7440N
I have a couple of times and liked it. In fact, a few times it resolved a printing issue that CURA couldn't fix... but I had to use a microSD card.
... that said, until either of these happen, I'm sticking with CURA:
1) Orca, etc. support direct USB printing
2) I own a printer that supports LAN and/or Wifi printing
It would be great to have a printer that would support USB !, I use both Micro and SD cards in mine and then can be a pain in the arse.. But I wouldn't change my printers for the world.. :)
O’ and the support you can get on here is second to none…
slicerman
Creality Ender 3 V2
I have been trying Orca slicer in place of Bambu Studio and noticed some advantages Orca appears to have over the Bambu version, using Bambu P1S
I tend to agree if you are happy with your current system then why bother, however IMO there is nothing lost in trying something new if you see that there may be some advantages quality/speed wise
I have not noticed nor tried to compare any "print quality" differences but my assumption is with the same settings in both slicers that there will be no difference, however I think Orca may have a few options that may be worthwhile considering
It seems to print a little faster than same model in Bambu
I like the calibration modules included in the slicer for convenience
Orca seems to get updates/improvements before they are included in Bambu if they are included at all.
Latest version I am looking at explained here
https://github.com/SoftFever/OrcaSlicer/releases
Overall I am happy to use either but I think that Orca may well nudge Bambu out of the way
Totally agree with what @Tony4597 said about Orca possibly nudging Bambu out. I’ve had a very similar experience. The built-in calibration tools alone save a ton of time, especially if you're switching filaments or trying to dial in speed vs. quality.
Administrator
Bay Area CA
If I end up getting a new printer that doesn't support connectivity via USB directly, I'll definitely be spending a lot more time with Orca since it seems like the go-to option for most people.
I'd keep using Orca even if it means you use an SD card to load the files to your printer. There are so many features in it that you discover the more you use it. I've been using it for 6 months and still finding new things it can do.
Administrator
Bay Area CA
ya, I'm thinking this will be like when I spent years in tinkercad and then finally moved to onshape, and wished I moved sooner.
I'm definitely way more familiar with CURA, and I love how easy it is to just send a print from my pc... but from what I understand, I can do the same using the web-interface for many of the new printers and control them / send the files wirelessly.
I’m sticking to CURA… If I can find the break, then I just might move on…:clap
Well I am still using Orca and the more I use it the more I find I can do.
Have you ever wanted to print parts with varying wall thickness and infill and do it easily in the slicer.
This video gives some great tips for using modifiers. I have linked to about half way in where he shows multiple parts on the buildplate being modified in different ways. The first part of the video may also be useful where he explains the basics of using modifiers.
I'm sure there are other slicers that can do this but I find Orca very easy to use.
Come on @The Hat - can I not persuade you to dump that ancient Slicer:celebrate
