- Jan 18, 2010
- Residing in Wicklow Ireland
I’ve been pretty quiet on my 3D printing of late because I’ve changed every wire in the loom from the plug to the nozzle head, I used this new radiator, thermistor, heater block and point 5 nozzle with a new fan also, even the Fang holding the fans was replaced, (Broke the existing one in the refit)
Here is the new radiator block and new Fang, and this is the multi wired plug that needs replacing too, because it’s not that easy to re-solder the wires back in and be sure everything is in the correct position and not shorting out.
click to enlarge..
When I get her up and running I’m planning on trying out the roll of Flexi filament I bought months ago, and if successful I might have a go at the PETG and then use up the last bit of ABS filament that’s been hanging around for the past 3 years.. Things could get interesting over the coming months.. Or not, everything might go pear shape..
click to enlarge..When I get her up and running I’m planning on trying out the roll of Flexi filament I bought months ago, and if successful I might have a go at the PETG and then use up the last bit of ABS filament that’s been hanging around for the past 3 years.. Things could get interesting over the coming months.. Or not, everything might go pear shape..
