- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
@stratman: Thanks for the lube info...
After all, in the inkjet arena, it's not quite the same as seeing a potential shark fin and wondering if you should call a specialist before you tell the swimmers in the water.
Understood but if you perhaps take a little step back and view the thread title you chose you can probably see why things got a little mixed up.Yes websnail/martin i thought i was clear in saying it was only "suspicion" and "tentative" from you that it may be the water.
Nothing wrong with your intentions, the road to hell n'all that But perhaps what we can all take away from this is it's best to perhaps pose a question "Could this be an issue" before ringing the klaxon.I actually posted this more see others are aware of a potential problem. Perhaps i should had labelled the thread POTENTIAL PROBLEM rather than warning. I can see how that sounds more alarmist
