- Jan 18, 2010
- Residing in Wicklow Ireland
@jimbo123, reading through your conundrum, I would like to get to grips with your situation.
First MP830 #1 died for no apparent reason and you then transferred MP830 #1’s head into MP830 #2 and it went down with much the same problem, "no power", so the score now is printers 2 and Jimbo nil.
This is where it gets a bit confusing dough, what happened to MP830 #3’s head that made you install a brand head in it in the first place and where did that head go after you removed it from MP830 #3, and also where is the original head from MP830 #2 ?
If you now have two MP830’s dead that won’t power on because you installed the same head in both (Test purposes) then it’s fair to assume the damaged head was the culprit and if you install a new/spare logic board in both printers, they’ll both power on once more minus the print head.
Am I getting warm or still in the freezer !stratman said:While the forum rarely gets feedback about actual transferring of problems from print head to logic board assay or vice versa
