cspeter8
- Aug 13, 2011
Just bought a canon mx870 printer, a cartridge resetter, and an ink refil kit consisting of 5 bottles of ink and some blunt-point hypodermic needles. Did lots of googling and found some youtube videos that showed how these are refilled. I always see a holder or cover that attaches to bottom of cartridge, and rubber stoppers that go into the hole that I drill in the top. First question: assuming these 2 items are really necessary, where can I buy them? I have been unable to find a supplier for them. I have been covering the bottom hole with black electrical tape while I fill into the top hole that I drilled, then I seal the top hole with celephane/scotch transparent tape. Then I take off the bottom tape and hope that the ink will stop dripping out.
Some problems I have:
1) my cyan cartridge got pretty messy filling it, and I neglected to reset the chip before fillng. The red light does not go on when it is supposed to with just this cartridge. I wiped off the ink that I could around the copper contacts, but still no light on the chip resetter. Should I rinse the cartridge off with water to try to get more ink off the outside of the cartridge? (edit: rinsed the cartridge under the faucett with fingers over the openings, dried it with paper towel and it is now working)
2) the big pgi-220 cartridge looked like it went totally empty. I put 1 ml of ink onto the sponge first with the cartridge upside down (one video says this helps to reduce leaking after it is filled), then covered the hole, then injected the ink in the top 1/8" drilled hole I made (drilled the hole while holding cartridge upsidedown to avoid plastic shavings falling inside the cartridge). The ink kept draining out the bottom till the cartridge was empty again!
Thanks for any help you can offer.
