MP210 capping station problem
Smile
Europe EU
Hello, I have MP210, the problem is that only black print head nozzles dries out in a day or two. The problem is resolved if you turn off the printer and print head is moved by hand to right size.
I replaced the capping station from another almost identical printer that uses same capping station, sorry forgot the model. This had no improvement whatsoever.
What could be the cause for the problem given the fact that another capping station was used and this made no improvement? Any ideas?
Łukasz
Poland
MG6250 (MG5150 before)
100% missing PGBK?
May be due some electrical failures either in PG-?? cartridge or carriage, or ribbon or mother board (very rare).
For instance lack of any following signals (every of it is provided by only single pin in cartridge connector):
- PG heat enable
- VHT
- serial clock
- latch signal
No error reported by printer if any of it is lost, and no print.
Ł.
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
Check the black rubber "surround" gasket around the PGBK purge pad carefully for mispositioning or distortion. Also check the underside of the print head for a surface defect that would cause a poor seal to this gasket.
Smile
Europe EU
100% missing PGBK?
- PG heat enable
- VHT
- serial clock
- latch signal
Ł.
If left for a week then YES, almost all nozzles missing.
If left for few days then NO, it looks as random dried nozzle patterns.
Smile
Europe EU
As I said the entire purge station "capping station from another" was replaced but it does not matter, same problem with old or this replacement purge station.
Note: The problem is resolved if you turn off the printer and print head is moved by hand to right size.
turbguy
Laramie, Wyoming
Sounds like the head is being wiped by something as you move it by hand...
Smile
Europe EU
Smile
Europe EU
The nozzle check above was done after I moved the print head with my hand, but it did not help that time, so really this is a mystery.
You’re going to need a new print head, because the yellow has gone beyond saving, sorry.. :(
Łukasz
Poland
To me it looks like something really wrong is going with ink inside both cartridges, but PGBK is going worse.
Ł.
