- Thread starter
- #11
- May 29, 2007
- Ghent, Belgium
- Epson SC-P800,WF-7840,XP-15000
Hi Martin,
I think it is due to the Inkowl profile. I have optimized that profile and normally the result are pretty good and quite neutral, but I think due to the dark area's so much ink has be laid down to get the right tone, causing clipping.
You will need a very sensitive scale to to weight up to 0,01 gram to get it really right. Yes ABW K6 ink set has been calculated by me.
Again: QTR is necessary to pull out the full potential of this ink set, but as you can see: even without it the results are really good indeed .
